Results 21 to 30 of 32
Thread: Possible to Splice a VGA to RCA cable?
  1. #21
    May 2007
    Random question, is there any way to make Alpine's touchscreen work for the computer?
  2. #22
    Newbie TheGemInIMan's Avatar
    Dec 2007
    Quote Originally Posted by A4ringedONE8T View Post
    Alright I got a cable coming, need to decipher the color codes and what goes to what.
    Now a VGA cable has horizontal and vertical sync which I know are very important but the alpine harness has only "C-Sync"
    What else besides the RGB colors and RGB ground needs to be connected?
    Well that's not a problem and it's easily fixed with a tiny circuit (1 TTL chip, 2 resistors, 2 capacitors) ... it combines both the V-Sync & H-Sync pulses into ONE called the C-Sync (Composite Sync) ...
    We'll sort that out when we get there ... Bearing in mind I'm flying blind here
    Might wanna throw that one into the LCD Topic thread ... I personally don't know, sorry ...
    cheers,
    Gem
  3. #23
    Dec 2007
    Here's a proposed circuit that combines the H-Sync & V-Sync signals to make the C-Sync pulse ... its based on Tomi Engdahl's circuit ...
    Tomi's' Circuit:
    http://www.epanorama.net/circuits/vga2rgbs.html
    Bearing in mind all Sync pulses here are TTL levels ...
    Mine:
    Updated (Click image for larger view)
    Simple ... small and hopefully powered by either the VGA connector or the NAV 'Brain' unit itself ... but NOT both ... the current drain will be very low ...
    Also added an extra external Audio IN socket (MONO) along with a Composite Video IN too ...
    cheers,
    Gem
  4. #24
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Since the Alpine take in RGB signal, do a search for PSOne TTL CSync.
    Doesn't look like it going to the trash after all.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #25
    May 2007
    Damn theres no way in hell Im going to get this wired to work. Someone want to do it if I send you the cables and pay you? If not your going to have to tell me exactly what I need to do. Whats going on with the H and V Sync in the middle of that diagram?
  6. #26
    Dec 2007
    Don't worry mate we'll get it going (somehow) ... if you can't or not able to then I'll build it for ya ... just thought you'd like the xperience
    Basically the circuit is setting up the pulses (combining them) so that the right Sync pulse gets through at the right time ... hence the XOR gates ... (X=Exclusive) ...
    The first two gates filter the pulses and set up the TTL signals ... it sorts out the polarities for the Sync pulses ...
    The second gate is the one that defines which Sync pulse gets through ... an output is valid if and only if one of the two input events occurs and the other input event does not occur ... i.e. only one pulse gets through at a time (one or the other but never both) ...
    UPDATE:
    The third gate is an INVERTER ...
    cheers,
    Gem
  7. #27
    Dec 2007
    Quote Originally Posted by MatrixPC View Post
    Blimey loads of stuff on the PSOne hack ... took my evening up ... nice & thanks ... might come in useful for this project ...
    cheers,
    Gem
  8. #28
    Sep 2003
    Beach City, Socal
    There is another option without building a TTL CSync circuit called "sync on green". A search for PSOne hack by Mpro use that method.
    The reason I mention about the PSOne hack is not how to get the sync signal, but the video card that support custom resolution. You guys may need to use it when putting thing together for the alpine screen.
  9. #29
    Dec 2007
    Thanks Matrix ... we'll give that a go before we try anything else ... appreciate the input ...
    Just waiting for Shawn to get his NAV cable ...
    cheers,
    Gem
  10. #30
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by TheGemInIMan View Post
    The third gate is just a buffer ...
    Inverter.
  1. Replies: 4
    Last Post: 08-09-2007, 01:18 PM
  2. is there such thing like RCA to VGA cable
    By dexy in forum LCD/Display
    Last Post: 05-27-2005, 07:22 AM
  3. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 06:07 PM
  4. Replies: 20
    Last Post: 07-14-2004, 03:23 PM
  5. Vga to Svideo cable?
    By si2001 in forum LCD/Display
    Last Post: 11-01-2003, 01:33 PM
