You could try adding a thin miniature relay inside your Lilliput ...
Cut one of your speaker wires and attach to the relay switch contacts (N.O.) between the two wires ... Wired so that the when ACC is on it switches the relay on ... or whenever your Lilliput comes on ... you could use the 12v supply inside the unit itself ...
There are relays out there that are 5mm thick ... and thinner ... I don't know how much room you have in there ...
[media]http://img-europe.electrocomponents.com/images/RF231236-02.jpg[/media]
When the ACC goes off the relay will cut the speaker connection ... and vice versa ...
Just a thought ...
cheers,
Gem
LinkBack URL
About LinkBacks
