Results 1 to 10 of 16
Thread: Startup Timer for Heater
    Jan 2006
    Hey,
    As we have set into winter I have the same problem with my carputer as last year. My usb support doesnt work in the cold. So long story short, I think im going to buy a 12v heating blanket and put that ontop of the computer so that I can get some instant heat when the car boots up. But I dont want this running all the time. I need someway to have it power up for lets say 120 seconds and then turn off, only being triggered by power input. I did a search for timers but it all seems on shutdown.
    Any thoughts?
    Thanks in advance!
    98 V6 Camry XLE
    Status-Everything is working again!
    No progress while I am in NYC
    Ze Worklog
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    When you say usb support, is it the built in usb that isnt functioning or are you using a separate usb pci card? Does you computer still bootup and everything else work? With a heater, you will have to wait atleast several minutes for the components to warm. Maybe a cheaper and more practical alternative is to just try adding a another usb pci card that works in the cold.
    Jan 2006
    No its in the in built usb. I think your saying to add another card. Its a laptop setup so theres no way to go about doing that. I think by adding a cheap heater, it would reduce the number of reboots etc. The heater should be warm in one min so ok. And coupled with remote start will be ok.
    Anythoughts on the timer?
    98 V6 Camry XLE
    Ze Worklog
    Oct 2006
    Las Vegas
    so, every time that the 'heater' is going to turn itself off, the car and the computer will be running correct?
    You could use the fusion brain. (keep in mind the brain will not activate anything until the computer is up and running)
    Power the 'heater' trough a normally open (87) contact of a 12 volt relay(call this relay A).
    Relay B (activated by the fusion brain) is in series with the coil side of Relay A, such that Relay A only turns on if ignition is on and fusion brain hasn't turned on Relay B (connected to normally closed contact 87a).
    Relay B is controlled by the fusion brain, and can be set to turn on a set time after the program automatically starts(some xml'ish skin writing is required, but in this case will be very easy).
    Relay A
    85- Accessory wire
    86- Relay B (30)
    30- Fused source for heater
    87- Heater, and maybe a led saying that the heater is on
    87a- Nothing
    Relay B
    85- }pin connector to brain
    86- }pin connector to brain
    30- Relay A (86)
    87- Nothing
    87a- Ground
    Then, through the skin you tell the brain to turn off X time after program initiates.
    You could also do it with capacitors and resistors, but 2 minutes is a long time for that.
    And then you'd have a bunch of more outputs and inputs you can set to control with your computerif you're in to that sort of thing.
    Edit: another thought:
    Use something like a neutral safety switch, so that when the car goes in to any position other than park, or neutral; Relay B picks up and turns off Relay A=> heater.
    But that opens up the need to have a third relay as a lock in so that the relay A will pick up while starting up the car, but will not turn on when the car is parked but not turned off.
    Jan 2006
    interesting. that could just work. or even better if I had the brain I could just set it to turn on using a temp sensor or something.
    my only concern is that because the brain is USB, will it not work if the computer is not giving a usb signal hence killing the entire plan? otherwise Im sold, I was actually thinking about going fusion for other reasons!
    98 V6 Camry XLE
    Ze Worklog
    Oct 2006
    Las Vegas
    I specifically wrote my recommendation taking the fact that the brain does (*almost) nothing when the car is off. The way I specified it, it wouldn't kill your plan.
    *almost refers to the fact that you can set digital outputs to turn off a specified time after the computer shuts down, iirc.
    Jan 2006
    Im still somewhat confused. Sorry.
    Wait I think I may just have understood it. In simpler terms the when the car is on but the computer on the pad would be on. When the computer comes on and runs for x period(lets say enough to safely know its not going to freeze again) then the brain turns off the pad. thats genius.
    sorry for not understanding the first time.
    So thats a viable option, do you think that would be alot better then using a similar system but instead of time turning on relay B it was a temprature controlled sensor?
    98 V6 Camry XLE
    Ze Worklog
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    i think this is way easier than you're making it. Just use a thermostat switch calibrated for your favorite temperature to operate the heating blanket relay. It sounds like what you want is to maintain above a temperature as long as the computer is operating, as opposed to raising it for a short time on startup.
    This is just an example of the type of switch you are looking for. They have bimetal discs in them that trigger after reaching a certain temperature threshold and come in all shapes and sizes and temperature ratings.
    So for example, same ambient air temp is 0 degrees celsius when you get into your car - you need heat, so you would have a thermostat switch that breaks when ambient temp reaches 20C. So you give your relay coil ignition power and put the thermostat switch inline with that, and then heavier gauge constant 12V through the relay to the blanket. This way you've got a blanket that gets you to operating temperature, always turns on when it's cooling off too much, and never stays on when things are warm enough, and is always off when the car is off.
    Probably not more than $10 worth of parts not counting the blanket.
    Jan 2006
    seems to make sense. however a quick google search didnt show much of where I could get that part. is that like a mouser or a radioshack kinda thing?
    Cheers
    98 V6 Camry XLE
    Ze Worklog
    Aug 2005
    Quote Originally Posted by GoHybrid View Post
    This sounds like a much better idea than my $120 temperature controlled relay i was going to buy.
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  2. 12 Volt Timer For Computer
    By kozmo in forum Power Supplies
    Last Post: 02-18-2007, 11:02 AM
  3. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 12:55 PM
  4. Replies: 19
    Last Post: 07-27-2006, 04:44 AM
  5. Timer Circuit
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 11-04-2005, 10:47 AM
