Results 1 to 10 of 10
Thread: Ext. Powered USB hub - why?
    May 2007
    I've searched for an answer to this and I can't find any specific reason. Why would I want to use an external powered usb hub vs a bus powered one? I remember reading a thread where the poster said he "learned his lesson" from using a bus powered one but didn't mention what happened?
    Is there potential to damage the system?
    Aug 1999
    Washington D.C.
    The difference is externally powered hubs can provide a full 500mA on each port on the hub. Bus powered hubs can only draw 500mA from the host controller(upstream) so for example with a 4 port hub can only allocate 100mA to each port (the remaining 100mA is used my the hub itself). A lot of USB devices require a full 500mA (called high current devices) such as wifi adapters or USB bus powered hard drives. If you plug a USB device that requires high current it will either: 1) not work at all 2) it will work interminably 3) act like it's working but not really work or 4) the operating system will shutdown the device give you a current overload error.
    #4 is what *should* happen 100% of the time per the USB spec, but in reality there are a lot of non-compliant USB devices out in the marketplace.
    I've never heard of any damage with caused by connecting high current devices to bus powered hubs, I think that's because the USB controllers are smart enought to shut themselves down if they get overloaded.
    Hope that helps.
    Nat
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Also, if you intend to mount a puter in the trunk and a drive or other items in the dash, you'll probably have power issues and intermitent failures or things jsut won't work at all.
    A powered hub up front alliviates these problems.
    cheers
    Leonardo Da Vinci
    FLAC -zip-'s Avatar
    Ontario/Canada
    Just want to chime in as I use a bus powered hub up front.
    Use common sense, the low powered items such as keyboards, mice, GPS, etc etc use the bus powered hub.
    For high powered USB Wifi, USB Bluetooth 2.0, DVDs etc plug directly into the USB supported on the mobo. I ran 3 USB extended cables into my glove box.
    A lot of carputer devices want their own dedicated port non-sharing.
    For example touch screens can be flaky and have a delay if on a USB hub. My Engenius USB Wifi demands a dedicated port as well this is recommended from the MFG. So you will need both, a hub and direct connection so you can afford the flexibility.
    I am running a 5port bus powered hub in the glovebox, never had an issue. I would not go any larger than that for the reasons mentioned above.
    With 6 ports on the mobo and 5 bus powered thats 11 USB ports that should be enough for almost anything. Not sure how many USB ports you have on the mobo.
    My system is in the trunk.
    Sound Stage
    Eclipse|MTX|Infinity
    May 2007
    Thanks guys!
    Oct 2007
    I have a 4 port 5V powered USB hub I have in my glove box from all my reading and understanding I should be able to run more than one device that draws power from this 4port hub..
    The problem I am having is that I can run my Verizon USB Broadband adaptor but then when I plug in another device like my blue tooth GPS which charges using 5V it gets no power until I unplug the verizon adaptor does anyone have any ideas?
    May 2007
    Quote Originally Posted by dmistry View Post
    How big is the ps that you are using to feed the hub? (In amps)
    You are probably going over what it can provide.................
    Leonardo Da Vinci
    Oct 2007
    ohh I dont know I got one of those adaptors from radioshack that plug in to the cig. lighter
    Whats the best way to get the 5v feed to the USB hub?
    May 2007
    Those wil lonly give you about 1 amp max.
    Each port on the hub is capable of 500ma each. And 1 amp is pretty easy to overdraw on usb equipment...........
    Need to see the specs on your equipment to know if you're trying to pull too much power from it.
    Leonardo Da Vinci
    Oct 2007
    Ok here goes:
    Progin 168 GPS -
    Power Consumption
    Main power input 5V DC input.
    Main power input 3.3 ±5% VDC from internal Lithium-ion battery pack
    Operation Current 45 mA total typical
    Battery
    Source Rechargeable and removable 1050 mAh Lithium-Ion battery with 5V DC input charging circuit
    and a Verizon USB720 Modem I can not find any power specs for this but the USB cable is split in to 2 USB heads if that means anything
  1. HOWTO: Power a USB Hub for the G4
    By god_of_cpu in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-05-2010, 10:17 PM
  2. How to power a USB hub
    By spoonraker in forum General MP3Car Discussion
    Last Post: 02-05-2010, 02:56 PM
  3. installing a powered USB Hub.....questions?
    By mygti02 in forum Power Supplies
    Last Post: 11-01-2007, 02:05 PM
  4. Powered USB Hubs?
    By Booger in forum Power Supplies
    Last Post: 06-09-2007, 09:21 AM
  5. USB hub does not always initialize on boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-29-2006, 04:41 AM
