Results 1 to 7 of 7
Thread: New remote start??
    May 2007
    New remote start??
    So i have been doing some research on the web trying to find out if i want to do a push button starter or get a keypad. I got to thinking if all you really need is a momentary 12v signal to kick over a relay then why couldnt you use something else like an old cell hone or pager. you could bust it open and wire the speaker for the ringer or the vibrate for the pager in the one side of the switch or relay and then start your car by phone. Even if the voltage from those are minimal you could step it up to 12v and still have the trigger come from a cell phone. Just think your buddy hits his remote to start his car and you call yours and it starts. Does this sound like it might work or have I been looking at too many websites??
    Jan 2007
    dundee, il
    Quote Originally Posted by Mtrhd329 View Post
    i dont see why it wouldn't work, but it would suck when you get some random wrong number calling, also if the phone rang/vibrated more than once, the starter would grind, or if it didn't ring/vibe long enough, it just wouldn't start.
    i was considering doing this with a cheap prepaid type phone, but never ended up following through on it.
    david
    May 2007
    Wichita, KS
    if you wanted to get really fancy you could do the prepaid phone, then get some gadget that only fires when it hears a specific tone. so you call into the phone, dial a couple numbers, and boom your car starts. this would also eliminate random calls and the rmultiple ring problem.....
    now that would be cool. not sure if its possible though (well im sure its possible but how much $$$ are you willing to spend?
    Mar 2006
    Colorado, but Canadian!
    Or you can just get a regular remote start with a satellite link (Audiovox CarLink is what I have) and then you dial a 1-800 number, enter your pin, and from there start, unlock, lock, pop the trunk whatever from anywhere in the world for free. Also can shut down the car remotely ehile in motion (Think car theft). Unit is like $100 flat out new, no monthly charges for life.
    1.9in x 2.9in -- 47mm x 73mm
    May 2007
    Wichita, KS
    Quote Originally Posted by 2k1Toaster View Post
    Where's the fun in that? (besides a good deal) :P
    http://www.freeinfosociety.com/elect...ew.php?id=1635
    i might actually try this...
    May 2007
    ya i was thinking about the mulitple rings.....maybe a latching relay setup so that once it gets the 12v it just stays on. Woul have to put some sort of signal off of an accesory(sp?) so that it can unlatch when the motor is running. maybe off the tach. seemed like good plan but it still needs a little fine tuning.
    Nov 2007
    Depending on the capabilities of the cell phone you plan on installing in the car, you could set the phone to not ring and not vibrate unless a call is received from a given contact/group of contacts. Then, assign whichever ring tone/ring once/vibrate necessary to get the pulse you want to only the numbers that are acceptable for car starting purpose (i.e., your home phone, cell phone, etc.).
    By using a single ring option, you might be able to avoid the grinding from multi-rings, and hopefully the 'approved only' contacts approach would prevent wrong numbers from starting your car unexpectedly.
  1. Replies: 7
    Last Post: 12-14-2009, 09:34 AM
  2. Problem with alarm - remote start (fuel pump off?)
    By urosbe in forum General Hardware Discussion
    Last Post: 10-19-2006, 09:47 AM
  3. Installing an alarm with remote start
    By cheerio in forum Newbie
    Last Post: 02-07-2005, 11:28 PM
  4. PC remote start - via remote on your key
    By SAScooby in forum Power Supplies
    Last Post: 04-15-2004, 01:33 AM
  5. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
