2k1toaster: Hi, the 3 pieces of new ram are definitely not ecc registered or buffered ram as these cost a lot more than the normal ones i'm using now and I do believe I've tested these rams on normal "low-end" non server based desktop mainboards and they worked fine. and yeah i plug an A/C 450w ATX psu directly to the mainboard and it failed to post. bummer... so in your opinion, is "mitxpc" non reliable? I'm hoping they prove you wrong....
cpsubrian: Hey, thanx for the chip in, but the mainboard I'm using is a CN700 board with a C7 cpu embedded so i doubt it has to do with wrong cpu chip. As for the stepdown on FSB speed, I think it can only be done WHEN i get to enter bios AFTER post, and we all know this is the problem i'm facing - no post...
So does this mean I wait for mitxpc to respond and if they don't, give up on them and buy from another GOOD online store and at the same time make sure everyone in the WWW (whole wide world) knows that they are not helpful when it comes to technical supprt??
