Results 1 to 4 of 4
Thread: M1-atx power supply not turning mobo on!??
    Jul 2007
    hey guys,
    Just got my car pc kit, and im having a few troubles getting the power supply to turn the pc on with ignition. Currently its being bench tested.
    I found it funny that a desktop pc switch when plugged into the mobo turns it on fine... has anyone got any suggestions as to why this might be happening?
    I am really lost on this matter.
    Thanks in advance
    Daniel
    Elsewhere
    How is the M1ATX wired up?
    do youy have the two-wire lead that goes from the M1 to the power switch headers on the motherboard? Have you tried reversing one end of that lead? Polarity matters on many motherboards.
    Have you tested the lines that go to 12v constant and 12v switched to make certain they provde 12v constant and 12v switched (by the ignition)?
    I suggest breaking out the multimeter.
    How about the Wiki?
    Apr 2006
    Dallas, Texas
    So wait, the M1-ATX also uses a +5 volt signal to start the motherboard. Do all of the Startup/Shutdown controllers use this?
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Not startup/shutdown controllers but ATX spec PSU's
  1. DSATX Power Supply on LV-673 MoBo
    By Caelric in forum Power Supplies
    Last Post: 12-17-2007, 03:21 PM
  2. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 12:17 PM
  3. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  4. ATX power supply question
    By dudah85 in forum Power Supplies
    Last Post: 10-10-2006, 04:49 PM
  5. FS: KeyPower 250w ATX power supply
    By nick9871 in forum Classified Archive
    Last Post: 11-13-2004, 06:30 PM
