Define "lower"................
Hey guys...I am trying to decide on which drive I want to use. I am looking at solid state drives to avoid any trouble that would be caused by vibrations, but even they have a minimum operating temperature of 32 degrees. Has anyone found a drive that will support lower temps?
Leonardo Da Vinci
my compact flash and 3.5" mechanical both worked fine over the last week and its been between 10 F and 30 F here in MI.
Jan Bennett
Thats -30 C to 85 C
-22 F to 185 F![]()
PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
I have a regular 2.5 inch Samsung drive and it works above -10 celsius.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Hi All!
I from Russia. We use simple disks of 2.5". The hard disk can not start at temperature -25 but when the car stands on warming up about 10 minutes all will start normally. Excuse for my English.
Covered here:
Want to:
