Results 1 to 10 of 16
Thread: make a constant 12v lighter socket switched?
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    how would i be abel to do this. i have a 98 blazer, and it has 3 lighter ports. one in the ash tray for "lighting one up", and 2 others for powered devices. i would like to make the 2 power socket ones to be switched. hot in run. most of the imports i have come across have that nifty feature, along with many others that i would like to have in my truck.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by americasfuture2 View Post
    Two easy ways:
    1. find a switched power source, wire to that. Not recommended unless you know you won't be overloading that circuit.
    2. Put a relay in the power line of the two "contant on" plugs. Use a switched power source to activate the relay. Recommended method.
    Cheers
    Leonardo Da Vinci
    Apr 2007
    Edmond, Ok
    i did think of that, but i do not have any switched power sources i can think of. atleast nowhere in the cabin.
    May 2007
    Ummm, not to make it obvious, but..............
    All you have to do is get up under the dash. Almost everything there is switched. Tap into a line and use it to signal the relay, it's a very low draw usually for the coil...........
    Leonardo Da Vinci
    Apr 2007
    Edmond, Ok
    most the wires under the dash are for the dash controls and driver info stuff. i guess ill look at my schems and see what is switched. i just didnt want to hafta dig through my dash just to find that "one wire". that means having to take my truckputer out and some of the wires, i am afrad of coming apart and not be able to repair them properly. like the blk/grn p1900 wire for the aopac power button. its very very thin and looks to be waaaay to delicate. almost like a 42000000000 GA. exagerating a bit, ya know what i mean.
    May 2007
    Whatever.
    Just back probe the connectors with a test light and stay away from anything that has to do with the airbag system.
    Or run a switched wire from you fuse panel once you find an empty switched source. Guaranteed to be an empty one there.............
    Leonardo Da Vinci
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Maybe im not understanding what he wants to do.... but cant you simply take the 12+v wire cut it into 2, then place a switch in the middle of the 2?
    May 2007
    Quote Originally Posted by HiJackZX1 View Post
    Yes.
    A relay is just a switch that you don't have to fool with. The switched 12v is just to turn the relay on and off.
    If you set it up right.........
    Leonardo Da Vinci
    Jul 2002
    Its interesting you want your accessory outlets switched. I know of people with vehicles where they are switched that want them just the opposite because they want to power things with the ignition off. This is just an observation and not a suggestion that you shouldn't do what you want to do.
    Since you're looking for switched power sources, and to me that means on or off with the ignition key switch, that's the place to start rather than randomly poking around looking for one.
    There should be at least one unswitched +12 wire from a fuse somewhere into the switch and at least one switched wire out. Right at the switch may not be a good place to physically make a connection, but the wires you want start there.
    I like the thought of looking at the schematics. I personally don't want to trust any randomly discovered wire that looks like it's switched +12 to be a good thing to tap into. The air bag stuff as noted is one. Personally, I'd never tap into unknown wires that appear to go on or off under the right conditions. They may or may not be able to provide even the low current required for a relay, or create a hazard if something goes wrong.
    Even after you know what you're connecting too, a low amp rating fuse isn't a bad idea in that wire near where you tap into the stock wiring. That way, if anything goes wrong with what you've added, you may avoid blowing a fuse that causes your engine to quit, or something else nasty.
    May 2007
    The relay will on draw (or sink if you prefer) what it requires. Meaning, if it runs on .5a, that's all it will draw. Putting it on a 20a circuit will not harm anything.
    Voltage is a different story.
    Doesn't hurt to check the diagrams though..............especially in todays era of "computerized" everything.
    Leonardo Da Vinci
  1. False floor
    By i3igmind in forum Fabrication
    Last Post: 02-04-2006, 10:28 PM
  2. How-To: Modifying the PW200
    By evandude in forum Power Supplies
    Last Post: 08-18-2005, 06:45 AM
  3. Turn Constant 12V to a momentary push w/ voltage change
    By KyleYankan in forum Hardware Development
    Last Post: 03-25-2005, 10:33 AM
  4. why not to use zener to make 12V DC??
    By embedded in forum Power Supplies
    Last Post: 04-26-2001, 08:54 PM
  5. How do i make -8V from 12V power?
    By helloman in forum Power Supplies
    Last Post: 04-26-2001, 12:33 PM
