Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 101 to 110 of 113
Thread: Cold weather operators, how do you keep the 'puter warm?
  1. #101
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    My M10000 and CF embedded OS setup booted no problem last winter on a -15F day. Took the media drive (3.5") a few minutes before the PC recognized it though.
  2. #102
    Dec 2008
    whatever heater setup you might come up with, its probably going to draw more power then the pc itself. it would likely be best to figure out a battery system that is capable of running the pc for at least 48 hours at idle while engine not running. in other words, just use the pc as a heater.... or just have a a/c plug sticking out your bumper like most people do in cold climates, for battery or block heaters...
  3. #103
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by trader007 View Post
    The best and most reliable answer is let the car and PC warm up, then start the PC. The car heater is a better answer than any solution an individual is likely going to come up with. Slowly warming the PC will limit damage as well.
    TruckinMP3
    Read the FAQ!
  4. #104
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Letting the PC warm up from the car's natural heat might work when it's only -10C, but as you start hitting lower temperatures it will take forever. Especially if your system is in the trunk like mine.
    The most reliable setup Ive tested is my current system. M2-ATX, Jetway J7F2WE2G (100% solid state capacitors), 80gb Seagate EE25 (extreme edition), and Lilliput EBY701. Not a single cold weather related issue so far, down to -30C. Hoping it'll get under -40C this winter, so I can test...
  5. #105
    Dec 2008
    Quote Originally Posted by TruckinMP3 View Post
    but if you have an intelligent power supply, its going to start the pc when the car starts....
  6. #106
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    My carpc is under the passenger seat, and when it hit 10F the other week it took about 15-20 minutes for the car to warm it up enough for the hard drive to be recognized. Maybe using a low power peltier directly on the center of the hard drive to keep the bearings warm?
  7. #107
    May 2007
    Wichita, KS
    unless u specifically included a switch in your set up that cuts off the 12v car on signal when u dont want it booting
  8. #108
    Jun 2002
    Colorado
    Quote Originally Posted by nobb View Post
    Sure, but your set up is not really the topic of the thread... neither is mine. It does not require any heat to boot either.
    TruckinMP3
    Read the FAQ!
  9. #109
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    i got a new setup, its now under the the seat, no problems jet
    Forum name..., mobo…………..............., temp startup, temp malfunction, age board..., power-supply..., harddrive.......,suspected failer
    Rijk………........, Commell 673NS…........., +9C……......., +4C……….........…, 17 moths...., M2 / DSX12VD.., SSD 8 Gb......., mobo
    andrewb........, EPIA-5000.................., -30..........., -42..................., 0 months ?., M2.................., ?.................., mobo
    andrewb........, EPIA-M10 /k..............., -35..........., -42..................., 0 months ?., M2.................., ?.................., mobo
    andrewb........, EPIA-MII-10K.............., -15..........., -42..................., 0 months ?., M2.................., ?.................., mobo
    cartft..........., Jetway 7F2WE-1G-OC..., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
    cartft..........., Jetway 7F2WE-1G3-OC., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
    cartft..........., Jetway 7F2WE-1G5-OC., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
    Maheriano....., Via Epia M10000..........., -17..........., -17..................., 24 months.., M1 ATX............, Toshiba 5400 RPM, Hard Drive
    nobb............, Via Epia M10000..........., -35C........., -35C................., 2 months..., M2-ATX........, Seagate EE25 ST940814AM (automotive grade, aftermarket model).......,...Hard drive wont spin fast enough[/quote]
    Rijk………........, intel dg45fc+E8500…..., -15C……......., ?.................…, 4 months...., M4 ................., SSD mtron 7500 (16Gb),
    Dec 2008
    Quote Originally Posted by Lithoss View Post
    how does that work with remote start? i guess it could still be done... more complicated though.
  1. M10000 mobo in cold weather (-40C)? Any problems?
    By nobb in forum General Hardware Discussion
    Last Post: 02-19-2008, 07:55 PM
  2. cold weather and my motorized touchscreen.
    By skywise in forum LCD/Display
    Last Post: 12-12-2006, 10:58 PM
  3. Carputer and cold weather... very cold!
    By Topper in forum General MP3Car Discussion
    Last Post: 07-14-2005, 08:41 PM
  4. Anyone else having any issues with Cold weather?
    By bry21317 in forum General Hardware Discussion
    Last Post: 01-25-2005, 10:42 PM
  5. Cold weather +LCD
    By Adragontattoo in forum LCD/Display
    Last Post: 10-13-2004, 11:25 AM
