Page 12 of 12 FirstFirst ... 23456789101112
Results 111 to 113 of 113
Thread: Cold weather operators, how do you keep the 'puter warm?
  1. #111
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    Quote Originally Posted by trader007 View Post
    how does that work with remote start? i guess it could still be done... more complicated though.
    This will only work if you have your mobo on a second battery. Cold doesn't only effect the cpc, but also your battery.
    I have the mobo hooked-up to the car-alarm, and it’s just on for like 20 seconds and in the -10°C I already notice the difference.
  2. #112
    May 2007
    Wichita, KS
    i dont have remote start... if thats what the topic of the discussion was about i apologize, i didnt realize.
    but ya it could be done. the easy route would be if you know your car will be cold soaked when u come back just flip the switch before you get out.
    the complicated way would be adding extra signals to your remote and having your remote starter controller know the difference somehow...
    another thought would maybe instead of it being a switch, make it a relay that is controlled by a thermostat. this would obviously need a override switch but doesnt sound too complicated. hmmm. i might look into this (im sure its been done many times).
    the biggest problem with my carpc in the cold is the screen. it is really unhappy and dim at temperatures where my hard drive etc is perfectly fine (ive never tried it below about 10F though so...)
  3. #113
    Variable Bitrate Deric's Avatar
    Sep 2006
    Just a tip but you can try putting this in a table format as it would be easier to read and type/update
    Quote Originally Posted by rijk View Post
    i got a new setup, its now under the the seat, no problems jet
    Forum name..., mobo…………..............., temp startup, temp malfunction, age board..., power-supply..., harddrive.......,suspected failer
    Rijk………........, Commell 673NS…........., +9C……......., +4C……….........…, 17 moths...., M2 / DSX12VD.., SSD 8 Gb......., mobo
    andrewb........, EPIA-5000.................., -30..........., -42..................., 0 months ?., M2.................., ?.................., mobo
    andrewb........, EPIA-M10 /k..............., -35..........., -42..................., 0 months ?., M2.................., ?.................., mobo
    andrewb........, EPIA-MII-10K.............., -15..........., -42..................., 0 months ?., M2.................., ?.................., mobo
    cartft..........., Jetway 7F2WE-1G-OC..., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
    cartft..........., Jetway 7F2WE-1G3-OC., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
    cartft..........., Jetway 7F2WE-1G5-OC., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
    Maheriano....., Via Epia M10000..........., -17..........., -17..................., 24 months.., M1 ATX............, Toshiba 5400 RPM, Hard Drive
    nobb............, Via Epia M10000..........., -35C........., -35C................., 2 months..., M2-ATX........, Seagate EE25 ST940814AM (automotive grade, aftermarket model).......,...Hard drive wont spin fast enough
    Rijk………........, intel dg45fc+E8500…..., -15C……......., ?.................…, 4 months...., M4 ................., SSD mtron 7500 (16Gb),
    __________________[/QUOTE]
  1. M10000 mobo in cold weather (-40C)? Any problems?
    By nobb in forum General Hardware Discussion
    Last Post: 02-19-2008, 06:55 PM
  2. cold weather and my motorized touchscreen.
    By skywise in forum LCD/Display
    Last Post: 12-12-2006, 09:58 PM
  3. Carputer and cold weather... very cold!
    By Topper in forum General MP3Car Discussion
    Last Post: 07-14-2005, 07:41 PM
  4. Anyone else having any issues with Cold weather?
    By bry21317 in forum General Hardware Discussion
    Last Post: 01-25-2005, 09:42 PM
  5. Cold weather +LCD
    By Adragontattoo in forum LCD/Display
    Last Post: 10-13-2004, 10:25 AM
