greatwhite: In one of your replies to one of my cold weather related posts, I somewhat recall you saying you had no problems in the cold Alaskan winters, so it must be your new upgrade. I once did consider a heater for my hard drive. Then after looking at manufacturer recommended specifications, most drives are listed as having a maximum recommended temperature gradient of 20 degrees celsius per hour. If you are trying to bring the drive from -20C to operating 0C in just a few minutes by a heater (exceeding specifications), I would think that this would probably kill your drive much sooner. People seem to say that it is the changes in temperature which kills
hardware (causing contractions/expansions), which is why there is all that debate about leaving computer on/turn it off. If you are okay with that, then maybe you could build a heater. I have tried building a 100watt blower type heater which blows hot hair onto my hard drive. That was terribly inefficient and you are probably better off building some type of heater which transfers heat to the drive via convection (such as wrapping the drive with ceramic resistors). In the end, I scrapped the idea and ended up going with an automotive boot drive. For my
music, I use a removable 80gb when it isnt winter, and a 2gb usb key during the cold.
