Results 1 to 10 of 17
Thread: XM Sound Quality: XM Direct vs. XMPCR?
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    I'm afraid that I already know the answer to my question but I want to ask anyway:
    I currently own and use an XMPCR with optical-out mod. The sound quality difference of the optical out as compared to the analog out is like night and day. The analog line out is horrible sounding, and the optical out sounds really, really nice!.
    The problem is that the optical mod is turning out to be very limiting for me. I'm in the process of upgrading my car pc, and it seems like everything I choose, I have to do so working around the need for an optical input for my XMPCR. Seems like the choices for that are either the Audigy 2NX USB sound card, or a few PCI sound cards out there (but the Audigy 2 NX seems to be the only one that allows you to use Optical In completely un-buffered, and passthrough to the analog output of the card). And XM is what I use most in the car
    So, all that being said, I'm just trying to weigh my options and determine whether the XM Direct is something that I can even consider? Has anyone here used both the XM Direct and the PCR? Is the analog line out sound quality of the Direct any better than the analog line out sound quality of the PCR?
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Quality will be the same, you will see the most quality gain with the type of connector (optical v regular)
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Constant Bitrate diosagain's Avatar
    Feb 2007
    New Jersey
    Did you figure out an answer to this Nola? I'm torn between buying the the XM PCR and the XM Direct and don't know which one to get. I am currently using the Roadie sound card and hoping it will work well with Road Runner.
    Mar 2006
    Colorado, but Canadian!
    The bandwith of the sat. stream itself is the limiting factor. You cant "upscale" audio like that. It will sound the same going out of either box.
    1.9in x 2.9in -- 47mm x 73mm
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    the XMD def. sounds like poo so i'd stick to what u have.
    Live mp3Car Facebook Chat
    Jun 2002
    Virginia
    I'm using the XMPCR. The sound quality isn't so good in its basic setup. I tried using it with optical and didn't notice any improvement, so to keep things simple in my setup I went back to the basic setup. The one thing I did which makes a huge sound improvement in XM is installed the "Enhancer" DSP plugin for Winamp. By using that in conjunction with the line-in plugin the sound quality of the XM output is improved considerably. It also makes a huge improvement in the sound quality of MP3 playback. Some people are purists and wouldn't consider using a DSP, but Enhancer is a really good one and makes dramatic improvement IMHO. Check it out at http://www.winamp.com/plugins/details/81361. The many positive user reviews are consistent with my experience.
    Feb 2003
    SE, PA
    Optical out for XMPCR makes a significant difference. If you didnt hear the difference its either your ear or other audio equipment that is preventing you from doing so.
    Back in 04 when this mod came out, there was a sound spectrum anaylsis somebody posted between the analog vs. digital - the difference was apparent.
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
    Jun 2002
    Virginia
    Quote Originally Posted by blazinlow View Post
    To each his own. I was using the same setup as you, including the Audigy, and noticed little, if any, difference. FWIW, there's not a thing wrong with my ears.
    Feb 2003
    SE, PA
    The fact that the Toslink mod eliminates that annoying background hum makes the mod worth it, regardless if the sound quality increases.
    Perphaps your stereo is the limiting factor. I know on my system, which is MB Quart/Eclipse/Phoenix Gold the difference was remarkable.
    Jan 2007
    New Orleans, LA
    I'm with blazin, kbreeden. If you truly didn't notice a drastic difference, something HAS to be up with your system, somewhere.
  1. Sound Quality
    By leperkuan in forum Newbie
    Last Post: 10-24-2007, 07:38 AM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 06:42 PM
  4. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  5. Direct Xm working as a XMPCR!!
    By KMorphosis in forum General Hardware Discussion
    Last Post: 10-07-2004, 11:37 PM
