Results 1 to 9 of 9
Thread: USB Jack mounted into dash?
    Low Bitrate 20mg's Avatar
    Oct 2007
    chico ca
    i have a 4 port hub in my dash.
    Dec 2007
    Mohnton, PA
    As I adapt the touchscreen to the dash kit, I also want to incorporate a USB jack into the dash kit so that I can simply plug in a flash-drive to add new media, etc.
    Has anyone done this?
    How about the Wiki?
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    yeah, i've done that. I havent done it in a volvo, so you have to be creative in where you want it. USB is good for about 16 feet i believe without having to have the signal reamplified. 16 feet is more than enough, though. go grab 2x6ft USB extensions (if you run the computer from the rear of your car) from either or radioshack or bestbuy or whathaveyou...then run them from the back. the only problem i have run into doing it this way is that if the touch screen is plugged into the same usb cable, there will be issues with how accurate your touch is on the screen and it will get frustrating. I also have the transflective, so it may be different with other touch screens.
    on my webpage pics, i may or may not have those USB pics uploaded, i havent looked in a long time. Ill go home today and put them up if they arent on it to give you some ideas.
    good luck
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
    Oct 2006
    yup ive done it, worked fine.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Ah............... yup.
    Not very hard, pretty common really...........................
    Leonardo Da Vinci
    FLAC SnyperBob's Avatar
    Nov 2001
    I have a 4 port hub in my dash
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Dec 2007
    Mohnton, PA
    I already have the USB extension cable, and a 4 port hub. I am going to plug the USB for the touchscreen into one of the ports, and 2 USB ports into the hub also. After I posted this, I realized I had my old desktop with (2) USB ports sitting right behind me. I pulled those out and will mount it right behind my dash kit so its really clean. Thanks for the links and responses.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB Adapter for XM Direct
    By timekiller in forum Linux
    Last Post: 10-16-2007, 12:21 AM
  3. USB sound + USB DVD = SLOW
    By TimW in forum General Hardware Discussion
    Last Post: 06-23-2006, 02:19 PM
  4. FS: Visor for scion xB with USB keyboard mounted
    By Deliriousvision in forum Classified Archive
    Last Post: 05-02-2006, 07:51 AM
  5. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
