Results 1 to 8 of 8
Thread: USING an SD card for a Hard Drive
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Lightbulb USING an SD card for a Hard Drive
    I am considering removing my hard drive and simply replacing it with an SD card. the reason being is it will be much easier for me to update and make back ups of. Ebay has a lot of adapters for such uses and I am curious to how reliable they are and if this is a practical idea.
    Will it slow down my computer alot?
    Is it a stable solution?
    Will they last longer than a hard drive?
    Has anyone done this before?
    THANK FOR YOU HELP
    New Age Garmin - Skin for RR
    Nov 2007
    Any reason you want to use SD instead of CF?
    Constant Bitrate jontz's Avatar
    Dec 2007
    Osceola, IN
    Most SD cards are slower than a desktop hard drive (probably more like a slow laptop hard drive), and the really really cheap SD cards won't last as long as a hard drive either. Some people think that because they have no moving parts, they should last forever, but this isn't true.
    If you really want to go ahead with this, I would do some research and buy the fastest card you can. Chances are it will also be the most reliable, and the most expensive. Don't cheap out here or you will not be a happy camper. A good SD card shouldn't cause stability problems either.
    Aug 2006
    West Allis, WI
    Quote Originally Posted by pokki View Post
    SD cards are more readily available and are a lot more popular. Plus I dont really see an advantage with CF over SD. SD also has no moving parts, I believe CF does. No moving parts more than likely means beter stability especially in cold climates.
    FLAC SFiorito's Avatar
    May 2004
    SD and CF are both flash drives (except MicroDrives). The advantage of CF is you can buy industrial drives which are meant to be used in "embedded" devices such as CarPCs. I would be careful with cheap eBay adapters since they may cause compatibility issues. Search the OS forums for more info on running XP off a flash drive.
    Nov 2007
    The benefit of compact flash is the pins can be made to directly match that of IDE, thus no processing is required when connecting a CF card to a PC.
    That and you can get CF cards that do 40mb/sec at reasonable prices.
    The followign site is a good place to start for solid state drive speeds:
    http://www.hjreggel.net/cardspeed/speed-cards.html
    Aug 2006
    West Allis, WI
    The benefit of compact flash is the pins can be made to directly Blah Blah Blah....
    Thanks for the info, this is what I was hoping to get. I think I will go with the CF card instead. Makes more sense.
    Jun 2010
    Using a camera card as a ssd
    Hi I am on line while typing this message using a 16gb TopRam SD card. I have tryed other type of cards but only TopRam work so don't buy any other type. I have tryed others and they won't work.
    I have tried both CF and SD and both work very well Be cafule what type of adaptor you purchase because some don't work. If you would like to know which ones I use email me back.
    I am using Fedora OS with this card it's a FREE OS and works well. Tryed installing windows XP on a 32gb card but doesen't work very well. If you want to goto 64gb you can get a SSD for under $200.00 that will work with windows XP or Windows 7.
    Rick
  1. Best location for putting MP3s - external hard drive, CD, primary hard drive?
    By jjwolkster in forum General Hardware Discussion
    Last Post: 09-27-2006, 11:32 AM
  2. WTB/WTTF - 1Gb SD Card / WiFi SD Card for iPaq
    By ukchris in forum Classified Archive
    Last Post: 12-11-2005, 01:34 PM
  3. MB870 & Slimline Floppy Drives
    By McGreggor in forum General Hardware Discussion
    Last Post: 11-09-2005, 07:32 AM
  4. hard drive head crashing?
    By the4ork in forum General Hardware Discussion
    Last Post: 03-06-2005, 12:40 AM
  5. Ultimate Hard Drive Mount or bad idea?
    By rockthevolvo in forum General Hardware Discussion
    Last Post: 08-29-2004, 05:22 PM
