Results 1 to 5 of 5
Thread: Which fuse type/holder do i really need?
    Jul 2002
    Houston, TX
    I have this do i really need this ?
    And the fuse holder i have says 30amps max (not 20 like on the site). i also have 30amp fuse.
    I'm running an 8awg wire directly from my battery to fuse to a distro block. I will be running screen, dvd, cb, a buncha stuff...
    Please lemme know, so i can take this **** back if i really need the other stuff.
    Thanks!
    Oct 2001
    Ontario, Canada
    if the holder that you have says 30A, and the fuse that you have is 30A, then you can pull 30A through it without worry. At 12V that's 360W. I suppose that it depends what you intend on powering through it and what the requirements of those devices are. But for almost any setup 30A will be more than enough.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
    Jul 2002
    Houston, TX
    DVD player, LCD (x3), CB radio, FM modulator.
    how many watts you figure that is?
    Jul 2002
    Houston, TX
    would i really see a difference in the use of either of these 2 holders?
    Oct 2001
    Ontario, Canada
    I doubt it.
    Try it. If there is a problem the fuse will break and then you can get a bigger fuse holder/fuse, but I bet that you will be fine with what you have.
