Results 1 to 5 of 5
Thread: mounting the case Upside down bad?
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    I just got my voom-pc2 case and i am thinking about mounting it upside down, is that bad for the motherboard? I read a thread about it a while while back, but cant find it anymore.
    Elsewhere
    Honestly, I don't think it would be an issue.
    The biggest concern I'd think would be the CPU cooler coming loose. If it's securely mounted, then that wouldn't be an issue.
    With motherboards that require a gooldy amount of cooling and a larger HSF, I wouldn't suggest it. With anything that you'd put in a Voom case, I think it would be OK.
    How about the Wiki?
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    Providing everything is securely mounted and there is proper cooling/ventilation then you should be fine. Keep in mind that heat rises so if you have poor ventilation you could be in trouble.
    Constant Bitrate jontz's Avatar
    Dec 2007
    Osceola, IN
    I agree, just make sure everything is secure and you shouldn't have any problems.
    May 2003
    Florida
    Well i just got done with installing. It look so good when upside down, but i did not want to take any risk with it ,so i cut lot of the glove to make it fit flat. It looks pretty good.
  1. Smallest case that can fit a 3.5 HD
    By iselfdevi in forum General Hardware Discussion
    Last Post: 09-08-2006, 01:22 AM
  2. Replies: 5
    Last Post: 03-31-2005, 03:07 PM
  3. How to mount circuit in metal case?
    By Arathranar in forum General Hardware Discussion
    Last Post: 03-23-2005, 07:35 PM
  4. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  5. 7" REDANT SCREENS (bad pixel) CHEAP
    By dscustoms in forum Classified Archive
    Last Post: 06-26-2002, 11:04 AM
