Results 1 to 9 of 9
Thread: 1998 Grand Prix Wire Diagram
    Jan 2008
    Hi sorry if i am posting in the wrong place but I am looking for a wire diagram for a stereo in a 1998 grand prix Gt.
    It would be greatly apreciated thanks.
    Elsewhere
    How about the Wiki?
    Constant Bitrate jontz's Avatar
    Dec 2007
    Osceola, IN
    I'm in a good mood, so here you go:
    Constant 12V+ Orange
    Switched 12V+ Yellow
    Ground Black
    Illumination Brown
    Dimmer Gray
    Antenna Trigger Pink
    Front Speakers 5 1/4" Doors
    Left Front (+) Tan
    Left Front (-) Gray
    Right Front (+) Light Green
    Right Front (-) Dark Green
    Rear Speakers 6" x 9" Rear Deck
    Left Rear (+) Brown
    Left Rear (-) Yellow
    Right Rear (+) Dark Blue
    Right Rear (-) Light Blue
    Remember, google is your friend. I searched and found this within 30 seconds, I am sure you can do the same...
    Jan 2008
    Thanks, that's actually what I did. I found one but it said this is not guarnteed and what not so I wanted to check to make sure it was accurate but in my car their are like blue wires with white stripe etc some wires have stripes but aren't in any diagram what does that mean?
    Dec 2007
    Osceola, IN
    Do you have a factory Bose system, or something along those lines? These diagrams are for the standard stereo. If you have a factory high end system it could be different.
    Jan 2008
    umm. I couldn't tell you. I'm putting in an aftermarket duel stereo. I'm changing it for the first time from the factory stereo.
    Dec 2007
    Osceola, IN
    Worst case scenario, take it down to the local pontiac dealership and they should be able to tell you.
    Jan 2008
    well it didnt work out :-/
    Motorization in the stereo works ( the specific radio i got the screen moves out and down to reveal another screen.) That works but the no power is getting to the actual stereo.
    Dec 2007
    Osceola, IN
    If you have gotten that far, then don't give up, you are close. All you need to do is take a multi meter and find where in the harness you have 12V power coming from. Keep in mind that you will probably have on 12V source that is always on and one that comes on with the ignition. Don't give up, you are almost there!
  1. [CoupeE46] BMW E46 2001 330ci CarPC ...
    By CoupeE46 in forum Worklogs
    Last Post: 10-02-2008, 08:16 AM
  2. Replies: 7
    Last Post: 02-08-2007, 04:39 PM
  3. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  4. Pure oxygen free wire?
    By Gearhead61 in forum Car Audio
    Last Post: 04-25-2006, 02:49 PM
  5. Electrical Diagram Help?
    By Optikal in forum General Hardware Discussion
    Last Post: 12-10-2004, 10:16 AM
