Results 1 to 9 of 9
Thread: IDE internal USB hub
    Jan 2008
    Hello, I have been lurking for a while but I finally have a a need to post. I am rebuilding a semi dead thinkpad r31. I have no USB2.0 and I was hoping to run an adapter from my spare 44 pin IDE port. I have searched google and others and the nearest I have found was for a pc (40 pin) IDE. Ideally I would like an internal IDE card reader capable of reading SD and CF1 while also being a USB hub. Would someone please direct me towards that appropriate product? Or is my only choice to run a 40/44 pin IDE adapter with the reader I have found so far?
    Thanks for any suggestions, I am at a loss.
    Adam
    Jan 2008
    I have seen a hack for the ide cable to turn it into a card reader. I cant remember where i saw it though, i think it was on the instructables website. If i remember i will PM it to you.
    Michael
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    http://www.milesie.co.uk/shop/asp/pr...asp?Product=38
    I've not seen an SD to IDE adapter. And the requirement for a USB hub in the same unit, running from IDE has me going "wtf...!" a bit. Got a link to one of these USB hubs that runs from IDE anywhere?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Rob Withey View Post
    HAHAHAHA, you can be so cold sometimes, but that is true. I dont think there is such a thing. If there is id like to see it.
    Where would the hub go? Inside the case? You would have to have a long IDE cable sticking out, that wouldnt look very plesant.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    I'm 99% sure you won't find a IDE to USB 2.0 hub.
    The IDE bus is designed specifically for communicating with hard drives / storage products. It is technically possible to create one if you created a device that changed the serial data from a USB device into parallel 40 pin IDE data, which would be detected as a hard drive, and then wrote drivers to communicate with such a device so it would appear as a USB hub to external software. But...
    Trying to get USB connectivity out of IDE, is basically the same as trying to connect a telescope to your nose. Your nose smells. Telescopes are for seeing through. I'm sure you could retrofit it into a smell-o-scope, but that would require many innovations and years of development. Why not just put the telescope to your eye instead?
    Solution for you: Buy a new laptop if you need USB connectivity. Or if you have a PCMCIA slot, use that for a USB hub. Otherwise, you are out of luck.
    Dec 2007
    DC Metro area
    No hard feelings, I just like using analogies to make my points. Good luck.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by krnpimpsta View Post
    Your nose smells
    lol... what does it smell like? and why are you smelling his nose anyways?
    Dec 2007
    DC Metro area
    What I'm doing smelling his nose is none of your business!
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    They are correct that an IDE port will not adapt to a USB hub. It will run a drive and that's pretty much it. There are adapters you can get to allow it to see flash media (SD, CF, etc) as a fixed hard drive.
    Your best bet is to get a pcmcia USB 2.0 card and a powered USB 2.0 hub. Run everything from the powered HUB to ensure all your devices get adequate power.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  3. Slim DVD & IDE to USB - DVD QLTY
    By ZimZimmer in forum Newbie
    Last Post: 01-19-2007, 06:37 PM
  4. Powered USB Hub
    By Belgiebob in forum Power Supplies
    Last Post: 01-08-2006, 10:53 AM
  5. Replies: 6
    Last Post: 12-27-2005, 02:41 AM
