Results 1 to 4 of 4
Thread: screen turns off and on when i hit a bump
    Dec 2007
    when i hit a bump in the road my screen flickers off and on.the bump doesnt even got to be a big bump.it happens all the time.my VGA connector on my laptop dose not have the screw holes on it.i reach down all the time to see if its plugged in and it is.dose anyone know what the most common problem for this,thanks for any help!!!
    Oct 2004
    NY
    def a loose connection somewhere... where is harder to say without looking at it, check & wiggle all your connections & See if you can find the culprit... if all connections are good then it is possible theres a bad connection inside the unit too, but it's definitely a bad connection somewhere
    Dec 2007
    thanks! i'll check them.this is my second monitor my first one did it too.it went for a ride out the window at 65mph.could the problem be inside the laptop.i was thinking on getting a usb video card off ebay.i drive a truck and the laptop bounces up and down in the passager seat.the laptop has about 500,000mi. of bumps on it
    Oct 2004
    NY
    the bad connection could be anywhere, including the laptop, if you had the same thing with prior screen then it's probably not the screen...
  1. Off - On - Momentary Switch?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 07-07-2003, 11:07 PM
