Results 1 to 10 of 17
Thread: airbag warning after taking apart dash board
    Jan 2008
    Dartmouth, MA
    Alright, today I took apart part of the dashboard in my 2002 Volvo S60. I took out the radio/cd player. To get there I also had to take out the climate control section. When I put everything back after I was done poking around, I turned on the car and my airbag light turns on and a message pops up saying to check airbags immediately. How can I fix this?
    Jul 2006
    seattle
    most likely it's just a loose cable, take apart everything and double check connection
    It happen to me once
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    If you cycled the key while your climate control was out, or left it on, thats most likely the Culprit. Volvos can system relies on the Climate module to relay signals to and from the SRS control module. Its the downside to computer controlled vehicles. Youll have to see your Volvo retailer to reset that one.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
    _
    Mar 2004
    Little Elm, Texas
    many vehicles rely on that kind of system.
    If my GTi, we removed the seat, cycled the key, then put the seat back in while working on the car...and we had the same thing happen.
    Jan Bennett
    Jan 2008
    Dartmouth, MA
    Alright, so my airbags should still be working properly then? How much do you think it would cost to have a dealer reset it?
    Feb 2006
    Atlanta Ga.
    Depending on the dealer, your relationship with them and their labor rate... Nothing more than 1 hr of their labor. Especially if you tell them you just want it reset, because you were fooling around with the radio and CCM and accidentally set it. If you are in there alot, and know your service advisor well enough, you might be able to get it knocked out for free. Figure 50-100 bucks though.
    Your airbags should still be working. The code is going to be something like : SRS module faulty communication with CEM . Everything works, but the light is still lit because there is a POTENTIAL problem as far as the computer is concerned.
    My worklog
    Maximum Bitrate pepsibobby's Avatar
    Dec 2005
    Kaiserslautern Germany
    check the connection under your passenger seat. i had this problem and by reconnecting it the light went away. The computer thought that the sensor was missing in the chair.
    Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by pepsibobby View Post
    I'll check it out, but I didn't touch anything under the seat so I don't see how this could have caused the problem.
    I also found a guide on how to reset the messages on the computer, but it doesn't reset critical messages and therefore didn't reset this one.
    Feb 2006
    Atlanta Ga.
    Chances are slim to none. If im not mistaken the main seat connectors under you seats are held together via a 7 or 8 mm bolt. I doubt it fell apart. Take my work on the Climate control module, I work on Volvos for a living.
    My worklog
    Jan 2008
    With most cars, if an airbag fault is detected they will NOT deploy in the event of a crash.
  1. Lilliput Button Board IR Extension
    By FLESIK in forum LCD/Display
    Last Post: 02-13-2007, 02:58 AM
  2. WTB Lilliput button/LED board
    By romeov in forum Classified Archive
    Last Post: 12-09-2005, 02:20 AM
  3. Dash board in primer
    By Skuzzle in forum Fabrication
    Last Post: 11-15-2005, 06:13 AM
  4. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 05:18 PM
  5. Mounting Labtop in car (dash board)
    By sleddog4 in forum General Hardware Discussion
    Last Post: 01-13-2001, 03:39 AM
