Results 1 to 3 of 3
Thread: Best way to control/ interface with computer
    Jun 2000
    toronto
    Post Best way to control/ interface with computer
    What is the best way to interface with the computer. My setup is that i have a lap top under the seat, it is linked to a desktop in the trunk.
    Basically I want to be able to switch between playlists without having to pull out the laptop. I was thinking a cheap solution is to use a number pad. Will winamp allow me to switch playlists using a numberpad? is there a better way to control it so that i can jump between different playlists or directories?
    May 2000
    Ft Gordon, GA
    Post
    winamp will allows you to switch playlists using a numeric keypad if you use blackwinds plugin.
    "if everything is under control, you're not going fast enough!"
    Jul 2000
    Ottawa, Canada
    Cool
    I'm using a cheap 5 $ gamepad and MindTwist (www.MindTwist.com). When you use MindTwist with Instadisc (on the MindTwist page), you can change playlist w/ the gamepad buttons.
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
