Results 1 to 6 of 6
Thread: having an issue!
    Dec 2007
    having an issue!
    Okay i got to testing my system here while i am finishing up my enclosure and the only time my lilliput will power on is when i turn on my xbox. I have the lilliput and the xbox running off an m2-atx and they both run great but why would the lilliput only work when the xbox is on? How do i fix this?
    _
    Mar 2004
    Little Elm, Texas
    It might need to see an input signal before it will do anything. No point in having a monitor on if there's nothing going to it, right?
    Jan Bennett
    Dec 2007
    also my m2 is not powering on my amps, anyone know why this is?
    Dec 2007
    okay after looking at it, the lcd definetly wont turn on without the xbox being on, which is weird because they are on seperate 12v wires, anyone have any idea why this would happen? I have the xbox wired up to the m2 with the xbox modchip. Need some help!
    Dec 2007
    Anyone have any input? I dont want to drive around with my xbox on all the time since i wont be playing it that often, would i be able to run the lcd power from the ignition switch for the radio? I am using that now to turn on the m2 and my amps, but i think i am going to run a switch to turn on my amps since im getting a faint pop when i turn on the xbox. I really need to know how to fix this! Thanks.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by tacobandit View Post
    Yes you can run the LCD from the 12V+ acc source from the radio harness. I have mine setup that way, since I have a rear view cam on the way and a PS2. I cant sit there and wait for the PC to come on before backing up.....
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  1. Audio issue with Intel Mini
    By iamgnat in forum MacCar
    Last Post: 06-27-2006, 07:01 PM
  2. what could cause high cpu issue (hardware related i believe?)
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 05-31-2006, 08:08 AM
  3. Xenarc causing noise (powering issue)
    By davem in forum LCD/Display
    Last Post: 05-20-2006, 03:01 PM
  4. BU-303 Issue
    By krazy1 in forum GPS
    Last Post: 03-10-2006, 08:14 AM
  5. More of a PSU/Inverter issue
    By slasherx in forum Power Supplies
    Last Post: 08-11-2004, 06:14 PM
