Results 1 to 10 of 20
Thread: Intel D201GLY2 low profile fan upgrade success! [pics]
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    Thumbs up Intel D201GLY2 low profile fan upgrade success! [pics]
    I've successfully upgraded the stock heatsink in the intel d201gly2 board to a Cooler Master EEB-N41SS-01 low profile fan+heatsink unit. This is to show that an upgrade to the heatsink can be done fairly simple!
    Cooler Master EEB-N41SS-01 - $6.99 plus shipping on mp3car store
    Arctic Alumina Thermal Paste - $4.99 plus tax at micro center
    Two reasons why anyone would wanna do this upgrade:
    1. The stock heatsink's height is almost twice as high as the motherboard height. So fitting it in a small thin case can be a problem.
    2. The stock heatsink is not very efficient at cooling the CPU. I found the idle temperature of the CPU to be around ~60 degrees Celsius, similar to what others reported. After the upgrade, my CPU temp. significantly dropped to 27 degrees Celsius and the highest under load being 31 degrees! THE CPU TEMPERATURE WAS CUT BY MORE THAN HALF!!!!!
    Before you attempt this upgrade, I just want to warn you that the coolermaster heatsink unit IS NOT a direct fit on the intel little valley board. The coolermaster was designed to work with 4 screws while the stock intel heatsink is held down by a strong spring pin! So what i basically did was used the stock spring pin and skillfully forced it down on the coolermaster heatsink. I'm not responsible for any damages this upgrade may do, I'm just here to report that it has worked very well for me!
    Stock D201GLY2 Board before upgrade
    Here you can see the processor after heatsink has been removed. The spring pin holding the heatsink is very stiff, so becareful and have some patience when removing it.
    A height comparison of the Coolermaster and the intel heatsink
    I cleaned the old thermal grease off the processor and apply new thermal grease onto the processor. Then I took apart the coolermaster fan/heatsink assembly and forced the stock spring pin(the original one holding down the stock heatsink) down on the coolermaster heatsink. The spring is very strong so it requires ALOT of force! Be careful when doing this, you dunt wanna break any capacitors or hurt yourself! Sorry no pics for this step.
    Here you can see the spring pin being forced through the coolermaster heatsink. notice how the middle fins are slightly bent?
    After installation of the coolermaster and motherboard fitted in the case.
    Because of this upgrade, i was able to fit the motherboard perfectly in my 1.5inch thick case!
    Everything fits, my CPU temp. is under 30 Degrees.....I'm a very happy man! Hope this little picture writeup will help some of you with the height and temperature concerns of the d201gly2 board! Goodluck!
    UPDATE 2/3/08: after running it this whole week....the CPU temperature actually isn't hovering around 30 degrees like i thought it would.....more like 50-55 degrees Celsius! Still an improvement over the stock heat sink but not a drastic improvement like i thought it would be! So maybe it still a good idea to add more case fans!
    Jul 2006
    seattle
    great how to!
    thanks.
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Some pics dont work??, but from reading it great job.
    Apr 2005
    Queens, NYC
    Quote Originally Posted by kickercivic1 View Post
    imageshack's servers are not the greatest. I updated the pics with mp3car host. It shouldn't have any problems now. Thanks for pointing it out!
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    Nicely done. I considered tacking a fan to the side of my heatsink to give it some more airflow. However, my case is doing pretty well for now since its aluminum, has fins and decent circulation from the case fan.
    Apr 2005
    Queens, NYC
    Dec 2005
    Raleigh, NC
    What about the other heat sink? The silentPC review said that also got very hot. Could that be heating up causing the reported temps you are seeing? I'm looking at getting a few of these and I'm OK with adding fans, just don't want to miss something.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
    Jan 2008
    Dallas, Texas
    I ended up putting a cheap P3 socket 370 heatsink & fan I picked up at my local Fry's for $7. It's not low profile, but it is almost exactly the same dimensions as the original heat sink except I get a fan included in that height. The 50mm ball bearing fan is fairly quiet and it keeps the CPU cooler. The one I got is an Evercool CF-5B-H.
    Now I just need to find a similar solution for the other heat sink.
    There are some larger capacitors on either side of the processor, so you have to be careful to get a heatsink that will fit.
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Do you have the model number of that second one you tried? I have that first cooler master heatsink/fan...maybe I can upgrade mine...
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Apr 2005
    Queens, NYC
    Quote Originally Posted by ik632 View Post
    i didnt bother with the northbridge heatsink. It does get fairly hot but i've got everything working well in my car now so i'm not gonna bother taking it out again to mess with it.
  1. where can I find low profile sound card?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-04-2006, 02:05 PM
  2. low profile PC2100 for Casetronics Travla c158
    By NJ_Jackals in forum General Hardware Discussion
    Last Post: 08-01-2005, 09:10 AM
  3. what can i fit in a low profile expansion slot??
    By m2rv h in forum General Hardware Discussion
    Last Post: 02-27-2005, 05:10 AM
  4. Low profile AMD XP 2500 heat sink (no fan)
    By Arathranar in forum General Hardware Discussion
    Last Post: 01-08-2005, 05:15 PM
  5. low profile high cooling fan?
    By spyhunter in forum General Hardware Discussion
    Last Post: 08-12-2002, 05:56 PM
