Using one instead of two means less power consumption (usually).
Just looking for opinions.
I've been using 2 old 4gig hard drives in my setup. Both in removable trays. So my music is split to two drives. I use batch files to operate the pc, so this hasn't been a problem.
I ordered a 40 gig 7200rpm drive and was planning on putting it in a secondary home computer (233mmx) to rip cd's.
So I'm wondering, should I just leave the 2 old drives alone since they are working fine. Or will there be any advantage to using the new 40gig drive in my truck pc. Any input?
aka Kumaneko
"Don't make me moderate your ***!"
Maxima of Doom - project thread - photo gallery
mp3car system is currently FUBAR and finances do not allow for a correction of that situation
Real computer hackers use a rotary cutting tool on their motherboard.
Thanks for replying.
What impact will this have on my system? Just curious. Is this the only main advantage to having one drive?
Maybe I'm just concerned about using a new drive in the vehicle. I've been using old drives because if they break, it didn't cost me anything.
Do you have more that 8GB worth of content you would like in the truck? If not don't worry about it. If you do, then install it.
2004 F350 Ext. Cab
System not reinstalled in it yet
if you dont need more room for storage, keep going with your existing hard drives.
if it isnt broked, dont fix it.
Project AutoBoxen: Coming along, almost ready to hook up in the car.
Celeron 500, 192mb ram, 8gb hdd, other stuff.
'91 Mazda 626: Its free, so ill use it.
Thanks for all of the input.
Well, it looks like the computers have made the decision for me. I hooked up the 40gig hd to the 233mmx home computer and the bios won't detect it. (So I assume the 166mmx in the truck won't see it either since I'm using DOS). But, Windows98 detects it once it's loaded. So I formatted and partitioned the drive and it shows the full drive at 39.xxx gigs. Since bios won't detect it, I can't use it as a main drive on the home or truckpc. So I'm setting it as a slave drive to store and backup my mp3s in case my truckpc fails. And I'll leave my 2-hd truck setup alone. It only takes a few extra seconds to remove 2 hd's anyway. I know that there may be ways around the bios thing, but until I get more than 8 gigs of music, it's not worth the effort.
Thanks for the help. By the way, if I'm doing any damage by using the drive in Windows even though the bios doesn't see it, PLEASE let me know.
geeze you can probably get a much faster computer for about the same that you paid for that drive :P
Don't forget, most drives come with an installation disk that will allow you to "Boot" off of your disk if your bios won't see it. So you can use that disk in just about any computer. But I agree with the others that you shouldnt' use that drive in your car unless you need to.
IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
Never, ever, ever use an overlay to install a drive. Ever.Originally posted by Telek
Don't forget, most drives come with an installation disk that will allow you to "Boot" off of your disk if your bios won't see it.Believe me, it will only cause problems in the future.
If all you're doing is running windows95 on an *in-car* PC that will only be used for playing music and a few other *automated* tasks and you won't be changing it much, using the overlay isn't a problem at all
On your main PC, no, I wouldn't suggest it, but I have seen people use it without issue. Certainly not if you're a big techie that loves to change your OS though![]()
