make sure hardware acceleration is turned off
If I hook up a second monitor and play a video file in windows media player the video only shows on one screen.
Even if the image is cloned between the two screens, the windows media player window will show up on both, but the video will only show up on one.
I thought I remembered hearing/reading about this before, but I cannot find anything about it again.
Jan Bennett
PC Components:
My work log
also check in tools option performance advanced turn off overlays
PC Components:
My work log
Turning hardware acceleration down quite a bit has done it. Basically, I had to turn it down to one level before it disabled multi monitor support...so sad. Damn old IBM laptop.
Thanks for the help!
Jan Bennett
