Results 1 to 2 of 2
Thread: PSU wiring questions!
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    My setup is massive, so massive it had so much cabling, which over time turned into one big tangled mess. I decided to take the CarPC out 100% and start from scratch, except for the 4 guage wire and circuit breakers... I actually organized it correctly the first time.
    I have alot of devices running off the PSU and I am worried that once I get the rest of my new equipment, it will over load the PSU, which is a OPUS 320.
    Here is the question. I have 2 cigarette lighter power adapters, that are connected to two 7 port hubs.... Will it be an issue to run those items from the 12V+ ACC source or should I keep them on the PSU?
    Also I have 4 screens. One is connected to the 12V+ ACC source, since I need it to turn on right away, due to a rear camera. Were should I run the other 3 from, the ACC source or the PSU? I know the two Lilliputs use 9 watts each, and the 4th screen uses 15 watts.
    In the end, Im just worried about straining the PSU.....
    Here are the stats of everything....
    Two 7 port hubs.... the adapters are 4.5V at 2000ma
    Two Lilliputs at 18 watts together
    One 15 inch screen at 15 watts
    I have not bought the new motherboard, but I was looking to get a Jetway J9F2-KHDE, with a Intel Duo 2 Core (T7300), 2 gigs of ram. Also adding a XM adapter to the mix, and possiably a few more items.....
    Do you think I will surpass the limits of my OPUS 320? I have a M2-ATX lying around, should I consider using it to power items?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Jul 2007
    Miami
    bump
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Couple quick wiring questions
    By elimenohpee in forum Power Supplies
    Last Post: 08-07-2007, 02:51 AM
  2. Opus MPC-ITX PS wiring questions
    By dorao in forum Power Supplies
    Last Post: 04-26-2006, 03:27 PM
  3. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  4. Plexi PSU wiring...
    By RaZor in forum Power Supplies
    Last Post: 03-21-2003, 06:18 PM
  5. Astec PSU questions
    By Machs_FueL in forum General Hardware Discussion
    Last Post: 07-26-2000, 11:52 PM
