Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Troubleshooting slim dvd drive issue
  1. #11
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Dan95five0,
    As I stated -- I moved on to firewire -- which has been MUCH more reliable. I had nothing but trouble trying to get usb external DVD drives to work. I would skip it and save the hassle....
  2. #12
    Newbie Nickman's Avatar
    Dec 2007
    Atlanta
    Need a slimdrive-to-firewire conversion similar to the USB one
    Unfortunately I have built my USB enclosure into my monitor bezzel.
    Does anyone know if there is a small firewire adapter kind of like the slimdrive-to-USB card in the cheap enclosure?
    Planning (0000000000) 100%
    Purchase (0000000000) 100%
    Fab/Install (000000000-) 95%
  3. #13
    Aug 2006
    PA
    [Off topic]
    Wow,
    That looks really nice job....
    [back to topic]
    What enclosure did you use? The one from mp3car?
  4. #14
    Dec 2007
    Atlanta
    [reply]
    Thanks. fabricated at home.
    [topic]
    I have the el cheapo from mp3car. I do regret it, but it is the only one that would fit where I needed. Eventually I am going to have to pull the whole thing apart and cut the "slim-drive to USB" out to replace it. Have you had any luck?
  5. #15
    Aug 2006
    PA
    No,
    No luck with that one... I am using this one now:
    http://www.meritline.com/usb-firewir...vd-cd-r-w.html
    Good luck.
  6. #16
    Dec 2007
    Atlanta
    Can you tell if there is anyway to pull that baby apart so that I can use the conversion hardware? I would like to avoid cutting the whole bezzel to pieces again.
    EDIT: I checked out that link again. It says it comes with a power cable. Is that powered via USB to standard DC, or can I power with firewire.
  7. #17
    Aug 2006
    PA
    Nickman,
    I power my dvd drive just by the firewire port (no external power). The enclosure has limited ability to be pulled apart. Since it's in my center console, I don't have access to it right now to tell you how much.
  8. #18
    Dec 2007
    Atlanta
    Thanks nasa!
  1. I think I blew my slim dvd drive, can i bring it back?
    By Ryan711 in forum Input Devices
    Last Post: 08-27-2007, 07:23 PM
  2. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 04:06 PM
  3. Mounting a slim DVD drive &USB socket
    By mindracing in forum General Hardware Discussion
    Last Post: 08-18-2005, 01:28 PM
  4. slim dvd and 2.5" hard drive cables
    By warnockm in forum General Hardware Discussion
    Last Post: 01-03-2005, 05:08 PM
  5. Extending USB 10' + for slim DVD drive.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-08-2004, 12:14 AM
