Results 1 to 10 of 18
Thread: Troubleshooting slim dvd drive issue
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi,
    I have been trying for the last 6+ months to get a usb dvd drive to work with my setup -- with no success.... Today's attempt is utilizing recently purchased equipment (from mp3car):
    Panasonic Slot Load CW-8124 DVD-ROM/CD-RW Combo Drive
    Ultra Slim External Enclosure USB 2.0
    My issue -- dvd drive is not seen by my BIOS (or WinXP). Although the salesman at mp3car had said that this drive would run off of usb power, If I just used on usb connector I got nothing. This adapter does come with a connector to allow plugging into a second usb port and suppling additional power. But since I I had already read that people didn't tend to get enough power from that combo either -- so I rewired the connector to come of my OPUS 120 5V line. With both connected I get flashing lights (if I press the eject button). But no signs of it from my boot screen (I have it setup to boot from usb dvd drive first) or Windows.
    --Update---
    I bought a 2nd enclosure (same type) from mp3car after verifying the drive worked by testing it in another system. With the 2nd enclosure (on my bench) I got the drive to be seen by both the BIOS and Windows using my main home machine. In the car, the dvd drive is only seen sporadically by the BIOS and only twice by WinXP. Worse, there are time when my external hard drive isn't seen (hadn't happened before) -- which is connected to the same powered hub. Even worse is when the BIOS freezes(ie: stops just before the memory check and doesn't respond to attempts to enter setup).
    Having searched the forums extensively, I have seen a lot of people using external dvd drives (such as this). Most of the time, when problems are reported it's attributed to power. However, I have ensured sufficient power is being provided (as best I can test). The other 2 areas identified as potential problems were cable lengths and poor quality cables. I have tried different usb cables of varying lengths(I actually had to do a lot of cable swapping just to get the drive working on the bench). I have tried with hubs and without. I have even tried different hardware combos (actually this is my 2nd combo -- look here to see my 1st
    DVD Drive Boot problems
    I'm totally at my wits end ::
    -- end update --
    Additionally, when I was testing this out (on my bench) I noticed something weird. I am using a desktop atx power supply to provide the 12V to the OPUS. In the course of testing, I had a one point the usb plug connected and the atx supply connected (but at the point, I had it unplugged) -- and watched with mild surprise as my atx power supply fan still ran. This surprised me as it indicated that the power from the usb port was flowing through the enclosure to the power cord connected to the OPUS and on to everything else connected to it (including the power supply).
    If this isn't what suppose to happen, please clue me in!
    So, I would appreciate any I can get!
    Nasa
    BTW: if I should just give up on using usb enclosures, that would be good to know as well.....
    Aug 2006
    PA
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    I dont want to read your book.lol but how are you powering this drive?
    Aug 2006
    PA
    I was trying to make the author of "war and peace" proud.....
    I have the drive powered via the usb cable (presently plugged into a powered usb hub). I also have the power plug wired into my opus 120 via a 5 volt supply line. The plug origanally was setup to plug into a usb hub, but noting some post on this forum - I rewired this plug into my converter.
    ptk
    ptk is offline
    Singapore
    dude, i suggest you meter your 5V line and see. your drive's behaviours looks like it's "undervolting". giving it enough current is not good enough if the voltage is belong par.
    also, some board keep voltage on USB 5v even on standby. that's the reason why some of us actually cut the 5v line in our usb cable connecting our pc to powerhubs.
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    Mar 2006
    Colorado, but Canadian!
    It definately seems like you are overloading your PSU. All your symptoms fit.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2006
    PA
    Thanks for the suggestions....
    I pulled out the trusty voltmeter and checked the line -- 5.02V. I tested when the system successfully booted up and after a reboot which led to a "BIOS freeze". Both cases were within .01V of each other.
    oh, one correction/clarification -- I actually have 2 DC-DC converters. One is the OPUS which runs my computer. The other is an M2-ATX, which I am using as a point solution. I incorrectly stated the OPUS in my original post. When the computer isn't connected to the powered hub which has both the external hard drive and dvd drive, it boots very reliably. So I don't expect any problems with the OPUS.
    Newbie Nickman's Avatar
    Dec 2007
    Atlanta
    nasa
    Did you ever get your slimdrive working. I am having similar problems. The drive will not be rcognized by my carputer or my main rig in the house. Any thoughts any one?
    Planning (0000000000) 100%
    Purchase (0000000000) 100%
    Fab/Install (000000000-) 95%
    Aug 2006
    PA
    Nickman,
    I have moved on to firewire.... So far it's worked better -- except for my cable falling out of it's connections.
    Nasa
    Oct 2006
    updates????
    same problem. dont know what to do next
    95 Mustang 5.0
    Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
    80% done
  1. I think I blew my slim dvd drive, can i bring it back?
    By Ryan711 in forum Input Devices
    Last Post: 08-27-2007, 08:23 PM
  2. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 05:06 PM
  3. Mounting a slim DVD drive &USB socket
    By mindracing in forum General Hardware Discussion
    Last Post: 08-18-2005, 02:28 PM
  4. slim dvd and 2.5" hard drive cables
    By warnockm in forum General Hardware Discussion
    Last Post: 01-03-2005, 06:08 PM
  5. Extending USB 10' + for slim DVD drive.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-08-2004, 01:14 AM
