Results 1 to 6 of 6
Thread: USB powered vs. non-powered hub?
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    Just wondering what the advantages are exactly of using a powered USB hub over a non-powered version.
    For what I will be using it for, I believe a non-powered will be fine. I'll be using it for my touchscreen input primarily. The only other things I can see plugging in to it would be a mouse and/or keyboard. Then at times possibly a USB flash card. Any thoughts?
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    the only reason to have a powered hub at all is becuase of... the extra power.
    if you have a hub and everything attached to it uses a lot of power, it can strain the usb port out of the computer, or the devices wont work properly
    but thats about it, the only reason u'd need a hub is if the devices need a lot of power
    but a mouse and keyboard would probably run fine on an unpowered hub
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    FC3S is correct assuming all of the devices you are attaching at any given time uses a total of 0.5A. If it's more than that you will need a powered hub. So from what you described I would think you would be ok, until you had all three devices connected at the same time -- that might pose a problem.
    Dec 2005
    Grand Blanc, MI
    Quote Originally Posted by nasa View Post
    Thanks you.
    I doubt I'll ever have all 3 attached at the same time regardless. Most likely just the TS and maybe the flash drive. The mouse and keyboard would only be used for troubleshooting or fine tuning/tweaking anyway. Just in case the CarPC gets
    CarPC:
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    some touchscreens have been knowen to not work unless they have access to high power usb ports
    also some portable drives work better with a powered hub,
    Dec 2005
    Grand Blanc, MI
    Well, if need be, I can get another USB extension cable for my TS which is what I'm using right now. That way it will have it's own dedicated line. Thanks for replies and good info about the TS using high power. Any idea why that is? Isn't the USB interface just for the TS "overlay" I guess you could call it?
    CarPC:
    Sound System:
  1. HOWTO: Power a USB Hub for the G4
    By god_of_cpu in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-05-2010, 10:17 PM
  2. How to power a USB hub
    By spoonraker in forum General MP3Car Discussion
    Last Post: 02-05-2010, 02:56 PM
  3. installing a powered USB Hub.....questions?
    By mygti02 in forum Power Supplies
    Last Post: 11-01-2007, 02:05 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  5. Powered USB Hub HELP!!
    By evilragu in forum Newbie
    Last Post: 07-23-2005, 08:14 PM
