thsis computer does not have a power button, what do i do?
there is no power button on this computer! help im a newbie
Are you trying to turn it on the work bench? It uses an ignition/signal wire to turn on (white wire). PM me if you have any other questions.
yes i am trying to turn it on from my workbench.could you please help me further
Ok red positive black negative white ignition to what pos neg constant or just a touch connecting to a battery to setup operating system
Oh man. You multi-posted. I'm offering no help.
With my power supply, it needs a constant 12V source to the ignition wire to stay on - otherwise it's configured to shut off. Dunno how yours might work tho.
I have a Voom PC let me see if I can help.
The Red goes to the Battery and the Black is your ground. For my White Ignition wire since I wanted to have the CarPC only on when I wanted it I ran a power wire to a switch and the other side of the switch to the White terminal on the CarPC.
The Red and black wire supply the power and ground, the white supplies the "hey, lets turn the damm computer on" signal.
