Results 1 to 4 of 4
Thread: What devices go to what?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Ok, my install has a massive setup, 22 USB port and only 3 of them are free!!!! The MoBo has or will have 6 onboard USB ports. What devices should go on these ports. i know some devices will not install correctly if put on a hub. Here is a list of the devices.
    1. Joystick 1, also for thumb drives
    2. Joystick 2, also for thumb drives
    3. 7 port hub 1
    4. ELM 327
    5. Sierra Aircard
    6. SoundBlaster Live
    7. 7 port hub 2
    8. Silabs FM Radio
    9. XM Radio adapter
    10. Bluetooth dongle
    11. K-90 touchscreen
    12. Lilliput touchscreen 1
    13. Lilliput touchscreen 2
    14. Mouse Reciever for wirless mice 1,2, and 3
    15. PS3 Thumbpad 1
    16. PS3 Thumbpad 2
    17. PS3 Thumbpad 3
    18. TMPS
    19. Belkin Wifi
    20. - 22. Spare
    I do know Hub one has to go on the onboard USB. So does the SoundBlaster Live and the ELM 327 (will not install unless on a onboard port, weird). What else should be on the onboard USB ports that will run bad on a hub.... I have 6 onboard.... I have 3 onboard left. Does the XM need to be on a onboard port or can it be on the hubs?
    Both hubs are powered by the way.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Mar 2004
    I had trouble with my touch screen when I had it and a hub both plugged into the same usb host controller. The touch screen would just randomly stop working. It worked completely fine once I switched which port the touch screen was plugged into.
    I know other people had similar problems
    Jul 2007
    Miami
    Quote Originally Posted by dyne View Post
    Do you mean taking it off of a hub and onto a onboard port.... I did have alignment issues, but i think I had them either way..
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Mar 2004
    you know how usb ports come off the motherboard in pairs? each one of those pairs plugs into a usb host controller on the motherboard.
    With my touchscreen at least, if you plugged in the touch screen to the same usb host controller as a hub, it would just stop working randomly. I'm not sure if it would cause alignment issues, though.
  1. Control devices via LPT and Bluetooth
    By Towar in forum Software & Software Development
    Last Post: 08-25-2008, 12:51 PM
  2. Too many USB devices
    By Dragonknell911 in forum General Hardware Discussion
    Last Post: 02-18-2006, 04:50 PM
  3. power to laptop and 3 mobile devices
    By thomasamiller in forum Power Supplies
    Last Post: 11-27-2005, 05:24 PM
  4. Can we get a forum devoted to input devices?
    By CA 3000GT in forum Mp3car Forum Suggestions/Comments
    Last Post: 01-27-2003, 03:40 AM
