Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Powering USB Hubs incar.
    Sep 2007
    West Springfield, MA
    I've been thinking of how to do this. I know it can be done, so many of you already do it. My problem is finding a 12v to 5v power adapter that puts out the same amps as the AC adapter included with the hub. The only adapters I can find are very low because they're used for charging iPods, cell phones and the like. How are you guys powering your hubs in you cars? I heard something mentioned about using the 5v power of the power supply. Does this work or is it a crazy theroy?
    Elsewhere
    Yes, you can tap the 5v from the power supply. It works as long as you don't overload the PSU.
    Another option is to purchase a point of load PSU like one of these: http://store.mp3car.com/Point_Of_Loa...plies_s/10.htm
    How about the Wiki?
    Feb 2007
    netherlands
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by DarquePervert View Post
    Quote Originally Posted by rijk View Post
    And if you don't want that you can use a P.O.L.
    hrmm...
    Jan Bennett
    Sep 2007
    So to power the hub off the PSU, I would just use the +5v and -5v leads and splice into them, correct?
    Elsewhere
    Yup.
    How about the Wiki?
    Sep 2007
    Thanks for the help.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by blackcobra487 View Post
    Actually that would be +5V and ground, red and black as found in a molex disk drive power plug.
    ~Jimmy
    Sep 2007
    Ok. That kept me from making a mistake. The plug you're refering to, is that the one that would plug into the back of a CD or floppy disk drive?
    Nov 2005
    Austin, Texas
    Yes
    ~Jimmy
  1. Powered USB Hubs?
    By Booger in forum Power Supplies
    Last Post: 06-09-2007, 09:21 AM
  2. USB hubs - are they generally repeaters?
    By Brycestro in forum General Hardware Discussion
    Last Post: 04-22-2007, 09:31 AM
  3. Question on powering USB devices off of 5v line on molex connector
    By S4Per in forum General Hardware Discussion
    Last Post: 11-03-2006, 03:44 PM
  4. Powering a USB Hub
    By ZR5 in forum General Hardware Discussion
    Last Post: 12-01-2005, 06:05 PM
  5. question about powering a usb rom
    By DSM97RS in forum General Hardware Discussion
    Last Post: 04-28-2004, 09:22 AM
