Results 1 to 10 of 14
Thread: MSI Fuzzy Motherboard Experiences?
    _
    Mar 2004
    Little Elm, Texas
    I've had my eye on this series of motherboards for some time now. Searching on here doesn't yield much in terms of reviews from real world experiences in the car.
    Fuzzy GM965
    Fuzzy 945GM2
    Fuzzy 945GM1
    Jan Bennett
    Oct 2006
    Las Vegas
    I am not fond of my 945GM1, the POST is Damn slow and there's not much for fixing it. MSI support has been bad with these "industrial" motherboards.
    Drivers links aren't obvious out on this model, and it only ships with a 64bit XP pro driver set disk. I have a thread somewhere that covers this and has links to the drivers.
    On the flip side, with a T5600/7200 it is pretty quick (but hard to keep cool in my little box). Only 1 BSOD so far.
    Nothing that makes me want to throw it at a wall, but to do it over again, I wouldn't pick this one.
    _
    Mar 2004
    Little Elm, Texas
    Thanks! The lack of support and the slow POST is very important for this hobby.
    Jan Bennett
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by RedGTiVR6 View Post
    Maybe you should also ask toaster, he seems to love the Fuzzy 945, infact he's turned me onto it. Does post time really matter? All it will add is about 5 seconds? What is the diffrence between the 945GM1 and the 945GM2. From what i have read its not worth getting the GM965. It is not that much faster then the 945s' and it is very picky with RAM timings.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    _
    Mar 2004
    Little Elm, Texas
    saying it has a 'slow POST' doesn't tell me that it's only a 5 second addition in time. it tells me that it's a slow post time. if it's too slow people won't buy it, which means it's inventory that's paid for and just sitting. It also means more support time for our staff. Time answers questions about why the POST takes so long.
    Jan Bennett
    Mar 2006
    Colorado, but Canadian!
    Yup I just bought the Fuzzy GM1. I love it.
    The POST times are just fine. The pre-post definately takes longer however (about 2 seconds).
    So you push the start button or turn on the car, then the fan spins full speed for a fraction of a second, stops, spinning, and then you hear the fan start again. That takes about 2 seconds. Then the screen flashes, and POST happens. If you optimize the BIOS by setting the HD to first boot device, manually enter HD settings not Auto, quick boot, disable legacy USB support, and such things. I am using 2Gb RAM, and I think it supports 4Gb, but the quick boot is very nice. I would say it is 10 seconds from off to the XP logo with the scrolling horiztonal bar. I get that number because I timed my old Commel LV-671, and it was insant begin posting, and took 8 seconds to that screen. So 8 + 2 = 10seconds.
    As far as drivers, it came with a CD. I popped it in, pushed "1 Click Install" and walked away. Came back after dinner and video, ethernet, USB, and audio drivers were installed and working.
    I had some problems with the Voom2 case I bought (at the mp3car store, came within the week I ordered too good job guys! ) with the molex connector on the back having loose metal pins. So I had some random reboots that after 3 days I pinned down to excessive jolts like potholes and such, leading me to think it was a loose wire. The remote amp wire had come loose as well as the constant power. So I removed that stupid connector and used my own industrial one and it works great. No resets or anything. The reason is so many hard resets while driving, has corrupted the video driver I have stored on the HD, so currently I am not using the video driver (using XP default) until my new 2.5" drive comes in and I will redo it.
    So I give it 2 thumbs up.
    Other reasons I chose it:
    supports 4Gb of RAM compared to the Jetway J9F2 2Gb RAM
    supports a wide array of RAM timings, as opposed the ****ty J9F2 that must have specificly timed, and specifically sided RAM.
    Supports Mobile C2D
    Supports Desktop RAM, none of that expensive laptop stuff needed.
    Has PS/2 Mouse and Keyboard connectors onboard, J9F2 doesn't
    Has 4 USB on the back, so I took out my USB hub
    The list goes on. I love this little board!!!!!!!!!
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2007
    Miami
    Quote Originally Posted by 2k1Toaster View Post
    Supports Mobile C2D
    HAHAHAHAHAHA, I see you've become biased towards Jetway, like I have become towards VIA. Its also good to know that some1 that knows what thier talking about came in and set the record straight.
    Opps, I meant 2 seconds longer, lol
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Low Bitrate nationapn's Avatar
    Jul 2007
    Randolph AFB, TX
    I also have the Fuzzy GM965 and am loving it. Toaster's numbers sound about right. The board stays cool, performs extremely well, and comes with decent sound/graphics cards built in. I also give it two thumbs up.
    Nov 2003
    I just bought on of these to replace my Jetway J7F2WE1G2E. The Jetway board was fast, but wouldn't display any video when booted at temperatures lower than ~60degF. Totally stupid!!
    The GM1 looks to be a pretty good upgrade in speed and features.
    Feb 2008
    Mesa,AZ
    Yes...make sure you get the right cpu for the right board. I got a Intel T7300 through Intel (I am an employee) and it didn't say socket P anywhere on the web page, and I bought a MSI fuzzy 945GM1 online and it is a socket M board.
    The Fuzzy 965GM is socket P.
  1. MSI Fuzzy 945GM1 Drivers (esp. ethernet) and Bios Update
    By h3rk in forum General Hardware Discussion
    Last Post: 07-13-2008, 11:06 AM
  2. Still Can't Get New Motherboard To Power Up
    By james33440 in forum General Hardware Discussion
    Last Post: 10-22-2005, 01:02 AM
  3. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  4. Which Motherboard to Choose
    Last Post: 06-07-2005, 11:35 PM
  5. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
