Im guessing no one has ever done the antenna amp solution?
I ordered the Antenna amp, it is supposed to give me a 20db gain. Lets see how it works!
From experience, i see that USB radios in a car enviroment are very very flakky. So I was doing research, but not sure if it will work on the Silab. Has anyone tried connecting a car antenna amplifier? Wonder if that will boost the signal enough that it works OK. If yes, how do you feel about the sucess, or was it a total flop?
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
This did not work at allllllll. I decided to use the Silabs on my Media Center PC, and by a Visteon HD Radio reciever.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
I wish I could have gone that route.... maybe its the way the car is designed, and the fact that I took of my long wire steel antenna and replaced it with a small flexable european style antenna....... Plus HD is cool, alot of stations in Miami are HD and have sub channels. Plus it was fairly cheap, considering other options like HQTC. The reciever and cable cost me $86.00 total.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
I also am using a USB FM radio and get fair to good reception from it. Really the reception is great, just looking for a way to remove the "scratches" that occur from time to time. My signal strength is great most of the time. I just used a regular car antenna and the USB radio from Brando. Sound quality is great really. Better than my regular head unit. Just need to work on getting rid of the scratches which I know are caused by electrical interference. I just made sure to run quality cables and ground the antenna right on the USB plug casing itself. Works great.
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
