Results 1 to 4 of 4
Thread: Soundworks + 12V Adaptor
    Nov 2002
    Northern Ireland
    First post!
    I've been lurking on this forum for months now and have managed to restrain the urge to post anything so far, having seen some of the flames for not using the search button...
    At the minute I'm only starting out my build and my car has no head unit or speakers and I know bugger all about car speakers and amps so....
    I've noticed that Cambridge Soundworks have a 12V cigarette lighter adapter and I've read on another post that the FPS2000 speakers take 12V...
    What do you think about using this setup in the car?
    Obviously I'd hide the speaker away so that it's not obvious that I'm using them....
    Huge.
    Nov 2002
    Northern Ireland
    Link to 12V car thing
    Here's the 12V Adapter....
    http://www.gearshark.com/cgi-bin/s/s...tem%3Da1p43012
    Just need to make 100% sure the speakers take 12V input.
    Jan 2002
    Canada
    I would be concerned about what noise might be brought into the system when the car is running. It's so cheap it probably doesn't filter much. No harm in trying it though.
    I use an Altec Lansing ACS 54 system in my car. I power both the speaker system and the computer from a 600w inverter. I think it's great, so I recommend you at least try it. Here's a link to my setup:
    http://www.seanster.com/mp3car/rev2/index.html
    -Seanster
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    My Cambride SW320's take 12V 1.5A
    So a cigarette adapter will probably burn up because they usually can't handle that kind of load.
