Results 1 to 4 of 4
Thread: Pci Extension
    Newbie scaff's Avatar
    Feb 2007
    Pci Extension
    Hi, i don't know if anyone has done this but I can't seem to find another thread on it.
    I have a voompc which has 1 pci slot the problem is there is only aprx. 1 inch height available for the card, so what I want to do is plug a cable into the existing slot run it out through the back of the pc and terminate it with a pci slot so I can added any card I wish, I could probably build this myself with the right materials ? but I don't realy have the time and patients for all the small connections.
    P.s. I'm in the UK
    Elsewhere
    Google for PCI RISER
    They are available. Make sure you get one that points in teh right direction. There are some that go left, others that go right.
    How about the Wiki?
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    I use a pci riser to mount my soundcard horizontally as my case wasn't tall enough to handle it vertically. It works fine, but I don't know if you would run into any issues using one that long.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    as already mentioned, you can get a riser card that will allow you to mount the card horizontally in the case (if it fits). if it won't fit horizontally then you can get a PCI "riser cable" that will allow mounting the card further away than a typical riser card (including outside of the case itself).
    good luck
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. PCI Extension and Graphics Card Hook UP
    By alienjj in forum General Hardware Discussion
    Last Post: 03-14-2005, 11:10 PM
  3. Cable Extension for PCI Slot- M10000
    By Tred in forum General Hardware Discussion
    Last Post: 11-21-2004, 10:08 PM
  4. pci extension cable, pci right angle
    By dim-8 in forum General Hardware Discussion
    Last Post: 10-09-2004, 08:05 AM
  5. PCI slot extension
    Last Post: 02-08-2004, 03:35 PM
