Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 54
Thread: IEI KINO-690S1 AMD Turion 64 Mini-ITX Mainboard
  1. #21
    Mar 2008
    SFL USA
    also add a fan near the mem cause the sodimms get really hot
  2. #22
    Mar 2008
    SFL USA
    I havent tried 800x480 but as far as hibernation resume i havent had any non windows related problems with it
  3. #23
    Mar 2008
    jmc1414, what kind of heatsink/fan combo are you using and are you happy with it ? Also what kind of case did you end up using or did you fab your own ?
    Cheers,
    orGSD
  4. #24
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by jmc1414 View Post
    Oh wow, thats going to be hard, my case is so limited in space......... but it already has alot of fans, so Im hoping they will be enough.
    Cheers,
    orGSD
    I ordered the one made by IEI. They say you can use a pentium M cpu fan, but when i received mine, it did not fit, so I decided to get the one made for the MoBo. Also another thing I hate about the 690S1, is that the USB connectors are switched.....
    Code:
    PIN 1: +5V        PIN 5: Ground
    PIN 2: USBP4N     PIN 6: USBP5P
    PIN 3: USBP4P     PIN 7: USBP5N
    PIN 4: Ground     PIN 8: +5V
    So if you have the plug with double rows, you have to redo one side to match the pin layout.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  5. #25
    Mar 2008
    Quote Originally Posted by HiJackZX1 View Post
    Is the pentium M one that didn't fit, the one you got off eBay ? And where did you get the IEI one from ?
    The one that looked interesting to me, but likely won't fit based off your experience is the SilverStone NT07-Pro. It is very quiet at a supposed 18.5dBA.
    Cheers,
    orGSD
  6. #26
    Jul 2007
    Miami
    Quote Originally Posted by orgsd View Post
    Cheers,
    orGSD
    Yes, off of Ebay, Im starting to hate ordering PC things from there. The site I ordered from seems to have every piece for the KINO-690S1, if you type the IEI product numbers in their search, it brings all the items up.... or at least the ones I was looking for. Here is the link to the fan http://www.orbitmicro.com/global/hig...hs-p-2183.html. It also seems to be a socket479, I just guess I was unlucky with Ebay.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  7. #27
    Mar 2008
    HiJackZX1,
    Have you by any chance been able to run that Matrox compatibility tool?
    I know things got delayed because of the heatsink mismatch, but I wanted to check just in case.
    I will keep your eBay cautioning in mind when it comes time for us to order parts. Are you otherwise happy with Orbitmicro? Their price on the 690S1 is $40 less than at LogicSupply. I have done business with LogicSupply before but this first build is going to be a prototype and $40 will cover a heatsink and several other needed parts!
    Cheers,
    orGSD
  8. #28
    Jul 2007
    Miami
    HiJackZX1,
    Cheers,
    orGSD
    LOL, i wish it was only that delay, I had a tonnnnnnnnnnnnnn of others. IDE wouldnt fit, so I had to buy sata adapters, waiting on those. Also the 3.5 to 2.5 has'nt arrived yet either. Without those 2 things, I cant even install the HDD or the DVD ROM. All the people I bought the things from, decided to send it USPS and we all know they arent very fast. It seems some unkown force is being a biatch, when it comes to my car and install.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  9. #29
    Mar 2008
    SFL USA
    I used a pentium M heatsink/fan i got cheap from newegg... i forget exactly but ill look later for the model. I had no problem with the fit but im not sure i would trust ebay without checking model numbers... again i forget exactly which case i went with but i will check that too... its mini-itx case with 1 pci slot and i had to do a LOT of fab on it... i basically just used the motherboard standoffs and then gutted the rest of the case and put stuff where i wanted it using my trusty dremmel and some epoxy. also cut new fan holes. i can post pics if anyone wants
  10. #30
    Mar 2008
    I am sorry to hear that. I have also called IEI to see if they could run that app, but I have a feeling the friendly anonymous folks here like yourself will pull through first
    I am glad for all the information your putting in this thread about this board, it will be very benificial to anyone else who is considering using it. I can imagine the USB tidbit from yesterday will prove very valuable and save a lot of time for the next person who comes along.
    If you happen to come across model numbers and or photos I would appreciate it. I am glad that there are other people out there with this board. As long as it can pass the tests from that Matrox program it will be the board which we will be getting! Having all the extra information and experience from you guys on it will help make some of the other decisions surrounding it (case & fab work, heatsink, general cooling, etc...). I am tossing around the idea of going with an extremely low wattage processor (AMD Sempron 2100+ TDP 9W) but am trying to find more information about it first. Otherwise I will go the system pull route like you guys most likely.
    Cheers,
    orGSD
  1. Power Supply for AMD Turion 64 x2 TL-60
    By tavenger5 in forum Power Supplies
    Last Post: 11-20-2007, 01:18 PM
  2. Help picking Cpu fan for AMD TURION 64 ML-28
    By jumbodogs in forum General Hardware Discussion
    Last Post: 06-19-2007, 09:45 PM
  3. FS: AMD Turion 64 (ML-34)
    By DrewSG in forum Classified Archive
    Last Post: 03-04-2007, 04:30 PM
  4. FEELER AMD 64 tower for mac mini or cash
    By sti robot in forum Classified Archive
    Last Post: 03-01-2006, 01:06 PM
  5. Bargain!! Via Epia Nehemiah 1ghz Mini Itx Mainboard
    By dave0109 in forum Classified Archive
    Last Post: 05-26-2004, 07:40 AM
