Results 1 to 2 of 2
Thread: Terratec Aureon 5.1 MKII USB problems
    May 2007
    Hi all,
    I just installed a Terratec Aureon 5.1 USB MKII soundcard in my car pc. I'm using Centrafuse 1.47.
    The Terratec-card is connected through an USB-hub connected to my J7F2WE1G5 motherboard.
    When Centrafuse starts it plays fine. When I use the prev/next-buttons it often plays fine as well but it's dead sure that if I change playlists it will scramble the music until I restart Centrafuse. Stopping/starting the music won't fix the problem.
    I tried to rebuild my library, switch between mp3/flac, disable onboard soundcard (in bios), select output in settings rather than having it on "auto", use prescan, downgrade driver.
    The problem is not just with Centrafuse. I've tested with Winamp as well and it's the same problem.
    Please help! - when it actually does play the sound quality is muuch better than my onboard soundcard.
    May 2007
    Problem solved.
    Had to move it from the USB hub to the mainboard directly.
  1. Problems with Holux 213 USB
    By Toad in forum GPS
    Last Post: 07-13-2007, 07:45 AM
  2. Replies: 2
    Last Post: 07-11-2007, 07:08 AM
  3. USB Bandwidth Problems???
    By Altimat in forum Software & Software Development
    Last Post: 04-19-2004, 05:20 PM
  4. USB Extension problems
    By slarty in forum Input Devices
    Last Post: 04-17-2004, 03:26 PM
  5. Terratec Aureon Usb audio
    By dim-8 in forum General Hardware Discussion
    Last Post: 03-10-2004, 06:51 PM
