Results 1 to 6 of 6
Thread: Hibernate/ Standby problem
    Low Bitrate frangolfgt's Avatar
    Jul 2006
    Lancs, UK
    Hi
    Please help if you can. My car pc is acting strange. Sometimes when i tell it to hibernate, it goes through the normal actions, you see the bar finish but the screen flashes and the pc comes back to the desktop. An icon the appears saying "The Input Output device detected an I/O error". When i try to hibernate again, the computer for some reason goes into standyby. I have to shut it down and reboot to have any chance of hibernating.
    This does not happen all the time and has no pattern to it from what I can see. I have set it up to hibernate on power button press, so when i remove my key it automatically hibernates. This also only works some of the time. I have tried various rr settings to do with hibernate but don't really know what im doing.
    Thanks in advance...
    Skins:
    /showthread.php?t=83814 (R.I.P.)
    /104373-golf-skin.html (R.I.P.)
    /106214-metal-spin-release.html(RIP)
    using own vw gypsy clone
    On 2nd PC: 1st one died.
    Feb 2005
    Cali
    Try DevCon
    Do a search for DevCon. It sounds like a USB device, likely a soundcard, is not responding properly to coming out of hibernation. DevCon will ensure that these devices start correctly from hibernation or standby.
    If you are using a USB GPS, look into Xport, as it does the same thing as DevCon and is a little easier to configure.
    Cheers
    Jul 2006
    Lancs, UK
    i have xport but what should i do with it? at the moment I use it to split my usb gps com port into 2 so i can use freedrive and the milage plugin, which both get gps data.
    Skins:
    Jul 2006
    Lancs, UK
    bump
    Skins:
    Jul 2006
    Lancs, UK
    Can no-body help?
    I have a Creative Soundblaster Surround 5.1 External USB Sound Card, usb gps (cant remember what model), and usb touch screen. I use xport to split the data from the gps to freedrive and milage plugin in roadrunner. I don't know what other settings are needed.
    Skins:
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Look at the list at the bottom of xport. Hit the little checkbox next to your audio device.
    If it helps, leave it that way.
  1. can't hibernate or standby in RR
    By NYCdesignkid in forum Road Runner
    Last Post: 03-27-2007, 02:53 PM
  2. Hibernate takes longer than 45 secs, big problem!
    By davem in forum General Hardware Discussion
    Last Post: 11-17-2005, 01:47 PM
  3. Standby or Hibernate w/ nlited windows
    By IntellaWorks in forum Power Supplies
    Last Post: 02-19-2005, 12:38 PM
  4. Standby or Hibernate
    By FalconPR in forum General Hardware Discussion
    Last Post: 03-21-2003, 12:20 AM
