Results 1 to 8 of 8
Thread: IDE to Mini IDE Question - Help Please
    Low Bitrate fixinstuff's Avatar
    Jul 2005
    Illinios
    Question IDE to Mini IDE Question - Help Please
    I need help identifying the correct installation of my harddrive. The IDE cable I have 44 pin to 40 pin can plug in either direction. I know from experience that the wrong way frys the harddrive. Can someone please identify the right way? I cant afford to fry another harddrive.
    Option A
    Option B
    Fixinstuff
    Been there, done that, replaced it with a smartphone.
    Scott AFB, IL
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Do you have a pin-out diagram for the motherboard and for the drive? If not I would strongly suggest you get those docs.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    does the hard drive have a pin missing on the bottom row of pins?
    and what brand is the drive?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Check the adapter very carefully. It usually will say which is up and down. from experience with the top of the hard drive facing up and the 4 pins that are kind of seperated and not used to the right of the drive with the pins facing you. The power adapter should go to the left. Here is a picture of mine.
    Sorry for the blurry images, but I do not know how to turn on the Macros feature on my phone....
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Jul 2005
    Illinios
    Quote Originally Posted by Woofnstuff View Post
    Yes, The problem is the cable doesn't, which allows it to plug in either way. The harddrive is Hitachi, bought it here.
    Fixinstuff
    Scott AFB, IL
    Jul 2005
    Illinios
    Quote Originally Posted by HiJackZX1 View Post
    Check the adapter very carefully. It usually will say which is up and down. The power adapter should go to the left.
    Thanks for the pictures. I will also try to find the documentation for the hardrive.
    Fixinstuff
    Scott AFB, IL
    Jan 2008
    Does the cable have a little red line down one side? That usually indicates Pin1. Check the drive for a little "1" printed on either side of the connector.
    Jul 2005
    Illinios
    Quote Originally Posted by Lovecraft View Post
    Learn something new every day. Yes it does have a red line. Thanks for the input.
    Fixinstuff
    Scott AFB, IL
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Overheating your Mac Mini - No problem!
    By Bugbyte in forum MacCar
    Last Post: 12-08-2006, 09:46 PM
  3. Need Mini PCI slots?
    By Giuliano in forum General Hardware Discussion
    Last Post: 12-06-2006, 01:52 PM
  4. 2005 Scion xA- Mac Mini
    By Doomspat in forum Worklogs
    Last Post: 11-27-2006, 10:07 AM
  5. IDE Cable Length Question.
    By BeAR in forum General Hardware Discussion
    Last Post: 10-18-2001, 12:48 PM
