Results 1 to 2 of 2
Thread: Relocating Head Unit
    Dec 2001
    I want to relocate my Head unit into my Center console.
    Is there an easy way to lenthen the radio wiring harness.
    I plan to soder extentions between the radio harness and the stock harness adapter. If there is an easier way let me know.
    Also is there any problem extending the antena cable?
    2004 F350 Ext. Cab
    System not reinstalled in it yet
    Oct 2001
    Ontario, Canada
    There is no problem with doing that. You might have to solder wires to each wire to extend them, but really you're only dealing with about a dozen wires, it'll only take a few minutes to solder them together.
    What type of HU do you have? Is it aftermarket? Do you already have a wiring harness for it? Just make sure that you use good quality wire for the job. You can easily get antenna extension cables that will allow you to run it wherever you want.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
