Page 1 of 13 1234567891011 ... LastLast
Results 1 to 10 of 121
Thread: Double din with slide out screen and slot DVD
    Nov 2006
    Hi Everybody,
    I have had a car pc in my car for a few years now and have been very happy with it.
    But I wanted something a bit fancier and more sturdy than what I currently have - so I am currently working on a double din unit that will be made of plastic and some kind of metal for the casing. It will have a slide out screen with the DVD drive behind it - just like the commercial units.
    I am still in the designing stage and will update this thread as I make progress.
    Nov 2006
    Here is where it is currently at - I hope to get a prototype happening in the next few weeks
    Mar 2006
    Colorado, but Canadian!
    How are you dealing with the fact that a 7" bare lcd is larger than double din standards?
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2006
    Here is an expanded view for those interested
    Nov 2006
    The LCD that I am using is within standards.
    The ISO standard is 182mm x 106mm
    The panel size is 166mm x 103mm
    Nobody actually uses the ISO standard anyway - and quite alot of head units are higher than the 106mm - but I plan to make mine fit within the 106mm for the metal frame and have the bezel stick out a bit (ISO standard says the bezel can be 120mm high)
    There are a few 7" commercial units that do the same kind of thing.
    Mar 2006
    Quote Originally Posted by deepgrey View Post
    Is this the widescreen 7" like the EBY701?
    Its a very tight fit, but if you can do it, good luck!
    Nov 2006
    It's a widescreen 7" yes - The bezel being 120mm should give me plenty of room to play with.
    it can be very close to the top and leave a little bit of room at the bottom for buttons.
    The image only has one button - but I plan to have a few on there - mainly just a power button - an open button and then 2 volume buttons.
    Nov 2006
    I am going into the plastic tooling place in the next week or so to finalize everything and get a rapid prototype done up.
    Then I can test it out and see if everything works.
    I have plans for using a stepper motor to open and close the unit.
    I might even get a few done up if anybody is interested - but obviously I will post some photos of my prototype first.
    Anybody got any recommendations on the design etc?
    Nov 2006
    I have added a clip on frame for it:
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I like what you've got so far, keep up the good work. I'm very interested in seeing your prototype. If it works out and you feel like making some more, I may be interested in one depending on price and if my existing screen would fit in it.
  1. Slot Load DVD in LCD Touch Screen
    By ilusnforc in forum LCD/Display
    Last Post: 12-22-2007, 02:39 AM
  2. Double Din: room for 7" lcd & slot load DVD?
    By jedymastyr in forum Newbie
    Last Post: 07-08-2006, 02:10 AM
  3. Double Din Case - No Monitor
    By thwack in forum Fabrication
    Last Post: 06-12-2006, 02:19 PM
  4. FS: VGA screen, PSU, Slot DVD, misc
    By djjazzman in forum Classified Archive
    Last Post: 08-18-2005, 05:36 PM
  5. What screen will fit in a double din?
    By vdubpsu in forum Newbie
    Last Post: 06-07-2005, 04:46 PM
