Results 1 to 4 of 4
Thread: Advice on how to mount screen on / in this dash
    Feb 2008
    Below is a pic of my cars dash. I have a nice 8 inch touchscreen monitor I want to add right in the middle where the old radio and empty socket currently are but the monitor is too big.
    I`ve checked the screen and if I can find a way of mounting the monitor on a stand that would fit at the bottom of the empty space it would not obscure my existing switches such as hazard lights etcetera so would not fail an MOT.
    However I am unsure of how to mount it there, any advice would be appreciated as its the best place to have it in my car (2001 Kia Shuma 1.6). I`m thinking maybe clamping a homemade stand in somehow at the moment but maybe someone here has had this issue and found a good way of solving it?
    The gap available is 9.8 cm high and 9 cm wide, I wonder if there is a simple way to attach some sort of stand perhaps?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Maybe you should change the screen to a 7 inch..... i had two 9 inch visors, but they were composite (bad for a PC), so i threw away the screens but kept the casing and the EBY701s' fit perfectly. Im sure if you take them out of the case, they will fit in that space.......
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by mentalmummy View Post
    If you don't mind not having the monitor permanently mounted in the dash, then why not just attach a rectangular piece of material shaped to fit in the cubby below the radio to the back of the screen, and then slide the mounting block combo into the cubby. A bit of foam tape or adhesive rubber strips on the mounting block would ensure a tight, stable fit. I think that would be far easier/less expensive/better looking than a separate stand with the screen mounted to it...and would have the additional benefit of being more stable if you are using a touchscreen.
    Feb 2008
    Quote Originally Posted by parksgm View Post
    That would make sense as I don`t really wish to remove te screen from the casing if I can help it. Any recommendations for a suitable material?
    It would be easier than changing to a smaller screen as am on a tight budget so this would be a great solution!
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 05:29 PM
  2. Dash Mount touch screen with DVD player
    By XCESIV in forum LCD/Display
    Last Post: 10-18-2007, 06:07 AM
  3. Need touch screen advice
    By sciff5 in forum LCD/Display
    Last Post: 05-29-2005, 09:58 PM
  4. in dash touch screen in Vaux Corsa (UK)
    By m2rv h in forum Show off your project
    Last Post: 09-06-2004, 08:57 AM
  5. 7-in in dash screen question
    By traitorhound in forum LCD/Display
    Last Post: 04-07-2003, 07:42 PM
