Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: BMW E60 install and I-Bus retrofit....tricky
  1. #21
    Oct 2009
    London
    Wow Joako,
    Thats the best description of the MOST bus that I have seen, despite searching forums many a time. It confirms what I thought that it is too complex to interfere with the MOST bus itself.
    However the LVDS connection is a video connection giving direct access to the display and I didn't realize until now it is also a standard connection just like the other video connections on a ITX PC, however the ITX PC must also have an LVDS connector. There are lots that can be found sites, by just searching "ITX LVDS", and use an adapter lead. I am just searching around to see what the options are as the video could be displayed on the screen, and then use a modified IPOD adapter it should be possible to use the PC as a media player to output mp3 sound or video.
    http://www.national.com/analog/autom...ation_displays
    LVDS TUTORIAL
    http://www.national.com/portal/site/...CRD&videotag=1
  2. #22
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by joako View Post
    Sorry I think we missed one huge point. The E60 is not using I-bus it is using MOST bus.
    First of all great post with all that MOST information, I'm sure that will help a lot of people in the future. (In fact I may hijack it and put it on BMW-Carputers.com.
    But You missed the one main point of the OP's original question. (See highlighted text)
    Quote Originally Posted by Craggy View Post
    Hi all, I am installing a carputer in my E60 and will post pics soon. I have a challenge in front of me and need some help.
    I cannot use the E60s MOST bus to control my carputer, as to the best of my knowledge there is no equivelant to Rolfs IBus adapter for the Most bus so[HL] what ive done so far is changed my steering wheel to an E46 M3 wheel with paddle shift etc[/HL]. I can now use the buttons with my IBus adapter to control Roadrunner ( in theory) What I need help with is setting up an independant IBus network in my car, what parts do I need from an E46 to relay messages from my wheel to the Ibus adapter? [HL]I've tried connecting the wheel directly to the IBus adapter and powering it but the IBus software doesent detect any button presses so perhaps I need an E46 BCM to relay the IBus traffic? Or does anybody on here know how I would build a small circuit to do this task for me?[/HL]
    Retrofitting IBus to a car that doesnt have it to control a carputer might be beneficial to a lot of people on here so any help would be great.
    Cheers.....
    He has replaced his steering wheel with an iBus compatible one and is/was looking to get that working.
    Now having successfully retrofitted an iBus compatible MF E46 steering wheel into an E36 I can say that all he needed is a 10K resistor.
  3. #23
    Oct 2009
    London
    Pin assignments at plug connector X13814
    1 E Signal, microphone Voice control microphone
    2 M Shielding Video module
    3 E Video signal, red Video module
    4 E Video signal, green Video module
    5 E Video signal, blue Video module
    6 E Signal, microphone Voice control microphone
    I think I need to take a closer look at the these, it looks like RGB and audio, inputs into the CCC. There must be a catch as this seems to simple! Also I noticed that the rear camera input connects here into Pin 2 and 4. This sounds reasonable as the RGB connection 4 is sync on green.
  4. #24
    Oct 2009
    London
    Anyone have pin-out details for the video module, as this must also pump RGB straight in to the CCC.
  5. #25
    Jun 2010
    Hi, sorry to drag up an old thread, but do you have the pinouts for this plug here (8 pin (4)) ? (and the smaller 4 pin plug of the external button)?
  6. #26
    Jun 2010
    Quote Originally Posted by ccfj1 View Post
    Never mind found it (I think).
    Controller plug (4) -------Small menu plug
    1: +12v
    2: GND
    3: --------------------->1: GND
    4: Can High
    5: Can Low
    6: --------------------->2: ptt
    7: --------------------->3: esc
    8: Not in use.
    -------------------------4: Back Light dimmer crt
