Results 1 to 6 of 6
Thread: Computer Next to Gas Tank .. Is it Safe?
    Variable Bitrate Area3's Avatar
    Mar 2007
    Garland, Texas, United States
    Moderators Please move If I am in the Wrong Place...
    Ok So I FOUND the Perfect place For my Carputer....
    The only problem Is it is Right next to The Gas Tank....
    Do you think that it will be a problem?
    It looks like it is just the Fill Neck and The Actual Tank is under the Car...
    But I just want to be safe and Make Sure....
    I will be making the case out of 3/4th Mdf..
    Microsoft Is a Evil Empire that has corrupted a generation!
    Thanks - Eric Scott
    Area 3 Productions
    www.myspace.com/area3
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    No problem. That's just the fill neck, as the actual tank is under the car...right next to the exhaust pipe. Also, the fuel tank itself likely has an electric fuel pump SUBMERGED in or hanging just above the gasoline. The key, as usual, is in proper design.
    Make sure to properly secure any box you build to the trunk floor...50 lbs. sliding around in your trunk with every turn is much more of a concern than a gas tank explosion.
    Also...you live in The Colony? I'm there quite frequently, as I have family there. Have you checked out the North Texas Meet thread (linked in my sig below)?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    My car was designed by Ford with the battery sitting roughly where your PC will go. The fuel filler is on that side too. I don't think you have anything to worry about.
    ~Jimmy
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    correct me if im wrong, but isnt there a barrier of sheet metal between the trunk and the fuel filler? Unless you plan on drilling on that side, its perfectly safe.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Mar 2007
    Quote Originally Posted by parksgm View Post
    Yes I have been to 2 meets And Have learned Alot We Also Are having a Meet on Saturday!
    Thanks - Eric Scott
    Area 3 Productions
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by Area3 View Post
    sweet. I'll check the meet thread.
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 09:51 AM
  2. Replies: 34
    Last Post: 05-27-2008, 08:19 AM
  3. Acetone to Increase Gas Milage?
    By kirbycope in forum Off Topic
    Last Post: 10-09-2005, 06:30 PM
  4. CNN Kid Spilling Gas all over the place
    By sdashiki in forum Off Topic
    Last Post: 09-26-2005, 11:55 AM
  5. Fuel tank burst of gas...problem???
    By PoBoy in forum Off Topic
    Last Post: 07-02-2002, 09:19 AM
