Results 1 to 4 of 4
Thread: Removable Hard Drive
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    I would like everyones thoughts on this.
    I have an old desk top pc that I am converting to a carputer. Because of the extreme cold weather here, I would like to be able to easily remove the hard drive when Im not in my truck. I was thinking of either buying an external hard drive or buy an external case for the salvaged hard drive from my old pc. It seems that the external hard drive would be easy enough to quickly remove. Most only have a usb connection. Being that I built a custom case under my seat, I was thinking about mounting brackets next to the seat to hold the drive while Im driving.
    Does this sound like it would work? I don't know if the pc can boat from an external drive through a usb. Any suggestions?
    Thanks in advance.
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    Getting windows to install on a USB based drive is difficult to say the least. Then, once it's installed, it can become very frustrating trying to load the swap file on it.
    We had this all done in my friends CarPC and then took the PC to the car. Blue screen every boot. I gave up and we modded a Mini-ITX case to hold a 3.5" HD. Worked great ever since.
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
    Nov 2007
    North Central PA
    I guess I'll figure something else out then. Not a biggie.
    Mar 2008
    Two additional solutions you may consider, to get around the speed problems of a USB drive, would be either Firewire or eSATA. Both would give you improved performance.
    As for the BSODs on booting from windows on a USB drive, I haven't used windows in a while, as long as the motherboard's BIOS supports USB booting however it shouldn't be a problem (at least isn't for linux).
  1. Lost the key to my removable hard drive
    By CoCa in forum General MP3Car Discussion
    Last Post: 11-08-2007, 12:40 PM
  2. Hard Drive Question
    By abarzabar in forum Car Audio
    Last Post: 11-01-2007, 02:42 AM
  3. Help!!! laptop hard drive
    By ashbosh in forum General Hardware Discussion
    Last Post: 07-15-2005, 01:34 PM
  4. Laptop Hard Drive in carputer...
    By Powers in forum Newbie
    Last Post: 05-08-2004, 10:37 PM
  5. Laptop Hard Drive Problems
    By Powers in forum General Hardware Discussion
    Last Post: 04-28-2004, 07:21 PM
