I pulled the knob off the top of my first one and it ruined the rheostat (or potentiometer).
Cut the knob off the second with a dremel
Anyways:
1. remove knob (pull it or cut it, proceed at your own risk!), you'll see a plastic knob on a shaft under it.
2. remove plastic knob (pull or cut)
3. remove glass bottom. Slip an exacto knife in between it and the aluminum body and go all the way around. It's only held on with silicon. Be careful not to slip and rip yourself open!
4. desoldier usb wire or cut aluminum housing. Desolder is easier, don't forget which wire goes where. Take pic or make a drawing.
6. unscrew nut around potentiometer shaft.
7. slide the guts out.
Easy as pie.
LinkBack URL
About LinkBacks
