Please note that you will need to install a USB keyboard (and a USB Mouse or
USB Touch Screen) for the Station in order to run Configuration Wizard to
setup the Host and Station. After the Station is working correctly, you can
then setup the Station to Auto Logon in
Windows and then unplug the Station's
USB keyboard. However, after unplugging the Station's keyboard, please note
that you should not run BeTwin Control Center --> Station Configuration, as it
will update the Station's configuration to be without a USB keyboard and the
Station will not launch (due to insufficient
hardware) after you restart
Windows.
