Results 1 to 4 of 4
Thread: Mini-ITX lan problems....
    Low Bitrate ZoLtRiX's Avatar
    Nov 2002
    Niagara Falls, Ontario
    Hey guys I have a Mini ITX and the lan was working fine for abit then seems like ever since i put on XP it started craping out...the Bios sees the card on start up. and windows XP sees it aswell says its working fine but I dont get that green light come on when I put my connection in. even when i fire it up. so I tried putting in a d-link card to see if its my Lan connection and the d-link works fine. as soon as i fire it up I see the ligth turn on my d=link card. when I try putting the cat 5 wire into the onboard Lan nothing dead. anyone have any Ideas?
    May 2002
    I've been running xp with no problem
    I also had no problem with 98se and 2000pro
    I think maybe your connector is borked?
    does it look like maybe one of the pins inside is ot of place? That'd be an easy solution.. other than that the thing may be no good.
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Sounds like a bad connector or bad chip.
    Jun 2002
    Da Frozen Tundra
    You don'thave a 'mini-itx' you have an EPIA. Mini-itx is the form factor. Kinda like baby AT, ATX, microATX, etc...
    Hope you got your network deal figured out. It's not likely to be a software problem because you should get a light as soon as the cable is plugged in (assuming you have the board powered up).
    ricko73@yahoo 1997 Blazer Dashpc Style!
    VIA EPIA-M 9000 Hauppauge WinTv (FM tuner), 256 MB, 40 GB HD
    Running Linux: Slackware 10.0, xmms, mplayer and Roadmap gps
